Failed to load project from the storage
Hey,
I have a problem running vba on my 64bit autocad 2010. I have 2 different pc's (1 laptop with 32 bit win 7 pro and acad 2010 and 1 desktop with 64bit win 7 pro and acad 2010) and on the laptop (32bit) the vba runs without any problems. When i try to run the same routine on the 64 bit system i always get some "automation error". anybody have any suggestions ?
Some more info on the 2 computers. they both run windows 7 pro and acad 2010 full not the LT.
Also when i open a dwg file on both my comp's) i always get the following error : Failed to load project from storage.
Anybody have an idea how to solve this problem ?
With kind regards,
You did read about this error on the AutoDesk website right? Error: failed to load project from file. VBA not installed or an incomplete installation.
  • 3 years later...
Hey,
I have the same problem and I do have all the wright software installed. I embedded the code into the drawing and tested, all working fine. Somehow opening the drawing the message shows up with "Failed to load project from the storage" and it doesn't work again. opening the VBA Manager the windoe for the Embedded Project: displays "Not Loaded" and the buttons for Extract and Embed are grayed out. Even reloading the dvb file does not let me re-embed the file.
What gives?
