ahadar002 Posted August 22, 2010 Posted August 22, 2010 i using autocad 2008. my zoomfactor default value changed to 12 and mbuttonpan to 0. i want to change it to 60 and 1 as default but every time it changes to 12 and 0 when i open autocad.please help me about this problem. Quote
lpseifert Posted August 22, 2010 Posted August 22, 2010 Both system variables are saved in the Registry, so they should default to to your changes... Maybe something in your Startup Suite or perhaps a third party application is changing them when you open a drawing. You could try adding this to your acaddoc.lsp file, but if your problem is caused by a 3rd party app that loads after acaddoc.lsp, it probably won't work. (setvar "zoomfactor" 60) (setvar "mbuttonpan" 1) Quote
ahadar002 Posted August 23, 2010 Author Posted August 23, 2010 where to put the code (setvar "zoomfactor" 60) (setvar "mbuttonpan" 1) in the acaddoc.lsp file can you provide me the whole code. Quote
lpseifert Posted August 23, 2010 Posted August 23, 2010 Put the code (already provided) in your acaddoc.lsp file. If you don't have one, create it. Look in Help for acaddoc.lsp. Quote
