I have recently noticed that I have a two bits of text in a drawing which have the same style (apparently) but display differently; one is bold, the other lighter and wider.
On 'LISTing' the following appears:
MTEXT Layer: "Textnotes"
Space: Model space
Handle = 37bbd
Style = "notes20hand"
Annotative: No
Width: 800
Normal: X= 0 Y= 0 Z= 1
Rotation: 0
Text height: 40
Line spacing: Multiple (1.000000x = 67)
Attachment: TopLeft
Flow direction: ByStyle
Contents: heavy and narrow
Command:
Command: list
1 found
Space: Model space
Handle = 37bbe
Annotative: No
Width: 800
Rotation: 0
Text height: 40
Attachment: TopLeft
Contents: {\W1;light and wide}
I had not realised in 20 years of using ACAD the possibility of putting curly brackets around the text and with starting \W1:.
And - where did it come from?
While investigating I see that the contents are shown, as in red above, in the Properties box but I had never noticed the brackets etc.
I have always thought formatting was controlled by the style and of course dialogue over-rides.:?:?
And - 'matching properties' does does not change the other - either way...?
I've posted enough about how I hate embedded formatting in MTEXT so I won't go on again but it has caught you out here. If you highlight some text in the MTEXT editor and apply a format override, such as text height or a font change you get exactly what you are seeing. An override really only visible in properties and one that is a pain to get rid of. There are a number of LISP routines out there to strip the formatting or you can explode the text back to DTEXT.
Well --- you live and learn; thanks Dave.
Certainly, I have never knowingly embedded formatting in MTEXT...
DTEXT:twisted::twisted::twisted::twisted::twisted::twisted::twisted:
I tried to change the Width setting in dialogue from the '1' shown and text did chang but '1' didn't ???
THEN changed my UNITS setting from 0 to 0.00 and decimal appeared in WIDTH setting, so, learned a bit more :D:D:D:D
It has been documented in the User's Guide since at least R14, and maybe even in R13... Here is a fairly new version of it.
rkmcswain, thanks for the link.
I guess I have never needed the info; everything always worked OK the dialogue box method...
I've always referred to the codes over the years when building MTEXT strings using lisp or VBA...
I have never used or needed those methods for bog standard notes... but still can't see when or why my 'normal' notes style got changed - in some cases...
