When searching for safearray I found different ones. I'm confused as to how to use. Can anyone fill me in?
You might try reading the Developer Documentation, via the Apropos menu search for "safearray."
Snippet:
vlax-make-safearray
Creates a safearray
(vlax-make-safearray type '(l-bound . u-bound)['(l-bound . u-bound)...)]
A maximum of 16 dimensions can be defined for an array. The elements in the array are initialized as follows:
Numbers
0
Strings
Zero-length string.
Booleans
:vlax-false
Object
nil
Variant
Uninitialized (vlax-vbEmpty)
Arguments
type
The type of safearray. Specify one of the following constants:
vlax-vbInteger (2) Integer
vlax-vbLong (3) Long integer
vlax-vbSingle (4) Single-precision floating-point number
vlax-vbDouble (5) Double-precision floating-point number
vlax-vbString (8 ) String
vlax-vbObject (9) Object
vlax-vbBoolean (11) Boolean
vlax-vbVariant (12) Variant
The integer shown in parentheses indicates the value to which the constant evaluates. It is recommended that you specify the constant in your argument, not the integer value, in case the value changes in later releases of AutoCAD.
Lower and upper index boundaries of a dimension.
Return Values
The safearray created.
Hope this helps!
