Counting Blocks
Michaels
Thanks for making me think it through, Lee! :thumbsup:
You're quite welcome :)
Just for fun, for those fussy with grammar:
(princ
 (strcat "\n<< There "
   (cond
     ( (not (setq ss (ssget "_X" '((0 . "INSERT"))))) "are no Blocks >>" )
     ( (= 1 (setq n (sslength ss))) "is 1 Block >>" )
     ( (strcat "are " (itoa n) " Blocks >>") )
  • Replies 33
  • BlackBox
    13
  • Lee Mac
    10
  • Michaels
    8
  • David Bethel
    3
And won't (sslength nil) give nil all the time if blocks are found or not ?
So that's logically return nil.
That is what we are testing for - (sslength nil) will error, so we must prevent such a case occurring.
(princ
(cond
Hilariously fitting, Lee. :lol:
(princ
   (cond
Yes, It is GREATLY fussy with grammer. :lol:
I guess you mean my formal writtings. :)
Thanks
(princ
   (cond
Just for fun...
(if  (= "The Soul of Wit" "Brevity")
 (setq LeeMac "Witty"))
:P
Just an FYI,
If (sslength ss) return is greater than 32767 entities, sslength returns a REAL, not an INT and will crash (itoa)
Out of habit, I use (rtos (sslength ss) 2 0)
-David
Just an FYI,
-David
Good to know, David!
Just an FYI,
-David
David, this would only be applicable on 16-bit systems, most systems today are at the very least 32-bit, some even 64-bit.
Lee,
Give it a try. I know A2K still has the limitation.
Array a line by 129 x 257 and try making a selection set of the lines and the check the length with (sslength) It should return 33153.
-David
Lee,
-David
AutoCAD Civil 3D 2009 Land Desktop Companion handles this without issue:
Command: (sslength (ssget))
Select objects: Specify opposite corner: 33153 found
Select objects:
33153
It took a while to complete the array command, but otherwise, no issue.
There shouldn't be a problem, as on a 32-bit system an INT is stored as 32bit signed two's-complement integer, hence it should go to 2,147,483,647 ((2^32 / 2) -1)
Command: (setq a 32767)
32767
Command: (itoa (1+ a))
"32768"
Command: (setq a 2147483647)
2147483647
"-2147483648"
I thought it was an ACAD only problem.......
No - it relates to the sizes of the different data types, here is a good reference - look at the 'Fundamental Data Types' section:
http://www.cplusplus.com/doc/tutorial/variables/
