Lee Mac Posted September 10, 2008 Posted September 10, 2008 I have a LISP that looks something like this (defun c:usermenu () (initget 2 "duplicate move rotate") (setq ans (getkword "\nAdjustment? (Duplicate/Move/Rotate): ")) (if (= ans "duplicate") (progn "Do a Copy, etc etc " ) ) (if (= ans "move") (progn "Move something, etc etc" .....You get the idea At the moment, if the user hits 'enter' when a keyword is requested, the program will end and do nothing, (which is fine). I would like the user to be able to select the option that he or she would like, AutoCAD to perform that option and then return to the keyword menu - and then if the user presses enter (with no keyword), the LISP routine will finish; or else (with a keyword) complete the option selected and again return to the menu. Any help is much appreciated. Quote
neekcotrack Posted September 10, 2008 Posted September 10, 2008 Here is a lisp that has what you want in it. You can us what you need. (defun c:setup ( / SHEET SCALE SF1) (initget "1 2 3 4 Exit") (setq SHEET (getkword "\nEnter Sheet [1]22X34,[2]24X36,[3]30X42,[4]36X48/<Exit>: ")) (if (or (not SHEET) (= SHEET "Exit")) (exit)) (initget "1 2 3 4 5 6 7 8 9 Exit") (setq SCALE (getkword "\nEnter Scale [1]FULL,[2]1/2,[3]1/4,[4]1/8,[5]1/20,[6]1/30,[7]1/40,[8]1/50,[9]custom/<Exit>: ")) (if (or (not SCALE) (= SCALE "Exit")) (exit)) (setq SCALE (cond ((= SCALE "1") 1.0) ((= SCALE "2") 24.0) ((= SCALE "3") 48.0) ((= SCALE "4") 96.0) ((= SCALE "5") 240.0) ((= SCALE "6") 360.0) ((= SCALE "7") 480.0) ((= SCALE "8") 600.0) ((= SCALE "9") (initget "Exit") (setq SF1 (getreal "\nEnter the desired scale factor/<Exit>: ")) (if (or (not SF1) (= SF1 "Exit")) (exit)) SF1 ) ;_ c9 ) ;_ cond ) ;_ setq (command ".DIMSCALE" SCALE ".LTSCALE" (/ SCALE 2.0)) (cond ((= SHEET "1") ;; 22X34 ;; DO SOMETHING FOR THIS SHEET ) ;_ c1 ((= SHEET "2") ;; 24X36 ;; DO SOMETHING FOR THIS SHEET ) ;_ c2 ((= SHEET "3") ;; 30X42 ;; DO SOMETHING FOR THIS SHEET ) ;_ c3 ((= SHEET "4") ;; 36X48 ;; DO SOMETHING FOR THIS SHEET ) ;_ c4 ) ;_ cond (princ "\nDimscale = ") (princ (getvar "dimscale")) (princ "\nLTscale = ") (princ (getvar "ltscale")) (princ) ) ;_ defun c:setup Hope this helps!!! Quote
ASMI Posted September 10, 2008 Posted September 10, 2008 For example: (defun c:test(/ cFlag ans) (while(not cFlag) (initget "Duplicate Move Rotate") (setq ans(getkword "\nAdjustment? [Duplicate/Move/Rotate]: ")) (cond ((= ans "Duplicate") (alert "You select Duplicate.\n\nPress Ok to return menu...") ); end condition #1 ((= ans "Move") (alert "You select Move.\n\nPress Ok to return menu...") ); end condition #2 ((= ans "Rotate") (alert "You select Rotate.\n\nPress Ok to return menu...") ); end condition #3 (T (alert "You press Enter.\n\nGoodbuy Lee Mac guy:)") (setq cFlag T) ); end condition #3 ); end cond ); end while (princ) ); end of c:test Because don't you localize your variables? In this case you must localize 'cFlag' variable or write (setq cFlag nil) at program begin. Localize is right way... Quote
neekcotrack Posted September 10, 2008 Posted September 10, 2008 If it was me I would use this lisp and just set my Default Mode under Righ-Click Customization, to be Repeat Last Command. So when the lisp ends, you can just do a right click to start it again or just go on about you business. I also change the key in command so you don't have to type out the whole thing just the first letter now. (defun c:test () (initget "D M R") (setq ans (getkword "\nAdjustment? [D]uplicate,[M]ove,[R]otate]: ")) (cond ((= ans "D") (command "_copy" pause pause) );end cond #1 ((= ans "M") (command "_move" pause pause) );end cond #2 ((= ans "R") (command "_rotate" pause pause pause) );end cond #3 );end cond (princ) );end c:test Quote
Lee Mac Posted September 10, 2008 Author Posted September 10, 2008 Thanks for all the help, much appreciated. I will most likely use your method ASMI thanks Because don't you localize your variables? I would localize normally, but I wrote the LISP quickly. Quote
Lee Mac Posted September 10, 2008 Author Posted September 10, 2008 ASMI, I have used your method and keep receiving an error like the one shown below: error - syntax error The error occurs upon loading the LISP routine. Any Ideas? Quote
ASMI Posted September 11, 2008 Posted September 11, 2008 error - syntax error Can be what be parenthsess are lost? Or error is outside this code? All works for me. It is too simple code not to work. Quote
Strix Posted September 11, 2008 Posted September 11, 2008 Can you please remember to use descriptive thread titles which help the search function to work! Quote
Lee Mac Posted September 13, 2008 Author Posted September 13, 2008 Many apologies Strix, wont happen again Quote
CAB Posted September 13, 2008 Posted September 13, 2008 This is a variation of the example from ASMI. It does not use the Flag variable but uses a progn to wrap the code. Basically the last return value is passed to the progn & it in turn passes this value to the while loop. So to exit the loop pass nil. To say in the loop pass a non nil value. The advantage is that you can call a routine from the cond and then have that routine return the value to exit or stay in the loop. (defun c:test (/ ans) (while (progn (initget "Duplicate Move Rotate") (setq ans (getkword "\nAdjustment? [Duplicate/Move/Rotate]: ")) (cond ((= ans "Duplicate") (alert "You select Duplicate.\n\nPress Ok to return menu...") t ; stay in loop ) ; end condition #1 ((= ans "Move") (alert "You select Move.\n\nPress Ok to return menu...") t ; stay in loop ) ; end condition #2 ((= ans "Rotate") (alert "You select Rotate.\n\nPress Ok to return menu...") t ; stay in loop ) ; end condition #3 (T (alert "You press Enter.\n\nGoodbuy Lee Mac guy:)") nil ; exit loop ) ; end condition #3 ) ; end cond ) ; end progn ) ; end while (princ) ) ; end of c:test Quote
CAB Posted September 13, 2008 Posted September 13, 2008 Lee Mac, You may edit your first post & change the thread title now. Maybe "Manage getkword Options" Quote
Lee Mac Posted September 14, 2008 Author Posted September 14, 2008 Thanks CAB, I have used ASMI's code and that seems to work, but as yours eliminates the need for the cFlag, I'll probably end up using that instead. Thanks as always. Quote
Lee Mac Posted September 14, 2008 Author Posted September 14, 2008 I have tried to change the title of the thread, but can only seem to change the title of my first post. Again, my apologies for my bad post. Quote
