I need to find out how to create a curb return table
with the following information
curb No.
Length
Radius
Delta
Tangent
Beginning of curve (station)
End of Curve (station)
from near alignment
So far I have been able to create the the table without the stationing
If you can help me out to find the way to imput the data in my table
will help me a lot.
Thanks
Hector
How did you create your table? I don't think C3D 2009 could do Line/Curve tables... So are you using Parcel or Alignment tables? Or plain Autocad tables?
Regardless, there's no easy way to create such a table in C3D, even in C3D 2011. The problem is the stationing - there's no way to create a General Line/Curve table that has start/end stations on it. In C3D, the only easy thing to do is create the curve table, and then label the station/offset of each end of the curves in plan view using a StationOffset Label. Getting stationing into tables pose a problem...
If it's possible at all using C3D tables in 2009, then I think the only hope at all is a Pipe Table. You would basically need to pretend your curb returns are pipes, at least as far as creating the table goes. Not sure if it will work or not, though... It would take some experimenting.
Under Civ3d 2011 menu option "Lines/curves" there is an option "Add tables" not sure if this helps I haven't used them.
As I use 2009 myself, I'm inclined to believe the OP might be using plain AutoCAD tables. If not, maybe the OP can clarify..?
You mean, like this: 8)
(defun c:CurveData (/ ss radius delta arcLen chordLen chordBear spStaOff epStaOff)
 (vl-load-com)
 [color=blue](cr_mnl)[/color]
[color=blue]  (if (not f:adproj)[/color]
[color=blue]    (load2 "ad" "adproj"))[/color]
 (cond
   (*activeDoc*)
   ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))
 (if (setq ss (ssget ":S:E" '((0 . "ARC"))))
     (vlax-for x (setq ss (vla-get-activeselectionset *activeDoc*))
       (setq radius (strcat "\n\t\tRADIUS         >>  " (rtos (vla-get-radius x) 2 2) "'"))
       (setq delta (strcat "\n\t\tDELTA          >>  " (angtos (abs (- (vla-get-startangle x) (vla-get-endangle x))) 1)))
       (setq arcLen (strcat "\n\t\tARC LENGTH     >>  " (rtos (vla-get-arclength x) 2 2) "'"))
       (setq chordLen (strcat "\n\t\tCHORD LENGTH   >>  " (rtos (distance (setq sp (vlax-curve-getstartpoint x)) (setq ep (vlax-curve-getendpoint x))) 2 2) "'"))
       (setq chordBear (strcat "\n\t\tCHORD BEARING  >>  " (angtos (angle sp ep) 4)))
       (setq spStaOff (strcat "\n\t\tBEGIN STATION  >>  " [color=blue](f:sta (car (f:gstaoff (f:ne sp))))[/color]))
       (setq epStaOff (strcat "\n\t\tEND STATION    >>  " [color=blue](f:sta (car (f:gstaoff (f:ne ep))))[/color])))
     (vla-delete ss)
     (textpage)
     (prompt "\nCurve Table: ")
     (prompt "\n---------------------------------- ")
     (prompt (strcat radius delta arcLen chordLen chordBear spStaOff epStaOff))
     (terpri)))
 (princ)) ;_end defun
Note - Program tested using C3D 2009 LDC.
Now all the OP needs to do is modify the code to plug the variables into an AutoCAD table of their choosing. :wink:
Hope this helps!
Civil 3D 2009? Or Land Desktop Companion 2009?
Sorry for not being more clear:
Note - Program tested using C3D 2009 [Land Desktop Companion].
[edit]
After additional testing, using C3D 2009 (non-LDC), the functions highlighted in blue above are not recognized. I will work to find their replacements for C3D, and report back if/when identified.
[/edit]
Edited by BlackBox
Additional testing comments
These were extracted from my previous post's edit, as there were beginning to be a couple of other potential solutions:
There's the Curve Calculator tool in C3D:
(._AeccCurveCalculator command, or Lines/Curves >> Curve Calculator)
There's the ._CGList command (not sure of the menu pull down?).
But this still does not plug the vlaues into a table, nor does it provide for the station and offset of the endpoints.
Hi I am using Civil 3D 2009 and I have to use a parcel table because
it is offset from the alignment.
This arcs are are part of the edge of road in an intersection and they have to be related
to the nearest alignment.
I can get stationing into the alignment table bbut not for this ones on the side
Thanks for your help
Hector
Don't look too hard... C3D is very different from LDC. To start, there is no concept of a "current alignment" in C3D. Making something similar that works in C3D will take a fair bit more effort...
I appreciate the feedback, Sinc.
I began to get that impression when I opened up C3D earlier today, sadly. While we all have C3D installed, it's not being used for production just yet, so they can finish setting up Styles, etc. But if you wouldn't mind educating me, how does one identify / label stations and offsets then? Is it simply relative to the dynamic assembly?
There are StationOffset labels, but they currently cannot be placed into a table. In general, Civil 3D lacks a way to create Station/Offset tables, except maybe in a Pipe Network table. That's why I was thinking that might be an option... Basically, instead of pretending the curb returns are Parcels, as the OP is doing, pretend they are Pipes... Not sure if it will work or not, though, since I've never had to do this task yet.
Understood, and thanks for your clarification, Sinc.
I think anyone using any LDT/LDC product, will be glad I posted my earlier code, I only wish it was helpful to the OP. :(
...Maybe next time!?
