Graphics Card performance - Autocad 2009 3d modelling
I have recently built a new pc and I am using Autocad Architecture 2009 (x64).
-Windows XP x64
-intel q6600 2.4Ghz @3.0Ghz
-8GB RAM
-ATI Radeon HD3870 @FireGL v7700
etc...
I have "softmodded" my HD3870 to a FireGL v7700, which happens to be a certified graphics card listed on the autodesk website. (this mod seems to be very common/popular on Guru3D)
I would like to know the best settings to get the most out of my graphics card, openGL or direct3D?
...also; I am confused as autocad still tells me that the card is not certified. I have applied the xml certification database update so something seems wrong. Does this matter?
Here is my 'TUNE LOG' (set at default settings) :
Performance Tuner Results Log
Version: 17.2.0.4
Date of Last Tune: 9/6/2008
Machine Configuration
Processor Speed : 3.0 GHz
RAM : 8190 MB
3D Device
Name : ATI FireGL V7700
Manufacturer : ATI
Chip set : FireGL V7700
Memory : 512.0 MB
Driver : 6.14.0010.6764
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: Software
Current Effect Status:
Enhanced 3D Performance: Not recommended and on
Smooth line display: Not available
Gooch shader: Software emulation in use
Per-pixel lighting: Not available
Full-shadow display: Not available
Texture compression: Not available
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth line display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
OpenGL driver: Not Certified
Effect support:
Enhanced 3D Performance: Available
Gooch shader: Available
Full-shadow display: Available
Texture compression: Available
Direct3D driver: Not Certified
Effect support:
Per-pixel lighting: Available
I have been using a low end onboard nvidia graphics card on my work computer, and i can't say i notice a great difference in performance between the two.(although i am working with a 40MB+ file)
I'm very new to autocad so my 3d work isn't complex. I plan to start learning 3DSmax when i get the chance, but on a glance I have noticed that the performance is alot better when orbitting.
Any help will be appreciated, thanks
AutoDesk says the future is DirectX. But for the immediate "future" I'd stick with OpenGL.
Ok thankyou, any answers on the certification database?
3ds max and autocad set the default settings to direct 3d; so maybe i should keep it on direct3d then?
Direct3D and OpenGL are listed as "not certified". What gives? You get a gaming card?
On newegg.com I have read reviews where a lot of your low to medium end workstation level graphics cards don't do a whole buncha good, most people say they aren't getting any better frame rates than a gaming card. You really have to get up in price for the performance increase.
Just a thought.... :)
..but the card is certified on the autodesk website. It is a gaming card but it has been softmodded to a v7700. Autocad 2009 recognises it as a v7700 so i can't see why it isn't "certified".
the actual v7700 retails around £500
