I write machine control software in C - directly generating stripped down simple DXF files in R12 export format.
Normally only LINE and ARC functions are required as the output is a series of enclosed convex polygons consisting of straight lines, arcs.
For one application, I have been requested to add a label to each polygon in its centre.
I need a basic AutoCAD command that writes text to an X,Y coordinate position, and that is R12 compatible.
Thanks.
I believe this AutoLISP command will work:
(command "._text" '([color=red]xCoord[/color] [color=red]yCoord[/color]) [color=red]TextHeight[/color] [color=red]RotationAngle[/color] [color=red]TextString[/color] "" "")
Just replace the red place holders with the described values you require.
That lisp will insert a piece of string using the current text style. Since the text style may or may not contain the text height, a problem will occur if Autolisp doesn't send the data as are expected.
Johnggold, it must be an AutoCAD command? If you write the file with your C program and assuming we are talking about an ASCII dxf file, you could put in something like this:
(0 . "TEXT")
(1 . "Blah-blah... content goes here")
(8 . "Layer name")
(10 Xposition Yposition)
For short text, this is the shortest DXF lisp (I think). There is no Zpozition in the last line, you asked for R12.
I didn't test it, but it should work.
Thanks. I will try that. zposition is not needed as its all 2D.
In the mean time I tested the solution I proposed. Well, the information is correct, but the topic is "AutoLisp like". With other words: it will not work in that form. Try this:
  0
TEXT
10
Xpos
20
Ypos
 1
text goes here
Searching for the minimal code, I see that also it worked without the layer code. The text goes on the layer 0
