"Save As..." will not pop up, text shows in the command line...
In the middle of the day yesterday this happened, I don't know if I hit a few wrong buttons or something or what, but when I do "Save As..." or Ctrl+Shft+S, either way the normal window that pop's up does not anymore. Text shows up in the command line but that's it. I tried all the Open & Save settings & nothing fixed it.
Please help, it is pretty frustrating :(
Please see the pict attached.
Try this:
(if (/= 1 (getvar 'filedia))
 (setvar 'filedia 1))
YAY!!!! That worked!!!!
Thank You so much!!!!!!!!!!:D
or simply...
filedia enter
1 enter
or simply...
filedia enter
1 enter
This is true... but I add the code I posted to my personal settings, loaded with ACADDOC.lsp :wink:
I posted to let the OP know that it wasn't necessary to use lisp to change it.
BTW... if you always want filedia=1, why the conditional?
Of course, I didn't mean to knock your doing so.
Good question...
I'm no expert, but the way I've learned, it is considered 'best practice' to conditionally set system variables, rather than force them no matter their value.
