Hello .
I have seen lots of users using the undo command in different types and return values.
So what are the complete types of undo command uses in Lisp ?
Some users prefer it (command "_.undo" "group") and others
(command "_.undo" "......... and so on.
Thanks.
I'm not sure I understand you correctly... do you mean this type of useage:
;; Set an undo mark
(vla-startundomark *activeDoc*)
Edit: If so, then inside the VLIDE, hit the Apropos button, and search for "undo"
Thanks a lot .
I meant the use of UNDO command itself .
Some users use it with "end" and "group" and I would like to know the rest of using operations with UNDO command.
And actually what's the meaning of group with undo ?
Appreciated a lot.
Command: UNDO
Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>:
Oooo... Alan, lucky post # 4,000!!!
Way to go big guy! :wink:
That's all I know with the normal use of Autocad command.
I meant there are lots of other uses of undo command with Lisp I have seen before ,and what I
could remember the one which is with group right now.
Regards
Ugh, I need to get back to work. :?
