Marc5 Posted August 30, 2010 Posted August 30, 2010 I figured out how to generate a room space under “Space Generator" and before I mess up, what I would like to do now (if I am able) is to change the Font Style from CAD default to Arial Narrow to the “Room Name” assigned to the space. How do I do this? Also, I would like for the Room Spaces to populate a Room Finish Schedule. Can this be done, if so, how? Thanks, Marc Quote
qball Posted August 30, 2010 Posted August 30, 2010 I'm not sure what "Space Generator" is. But if you type "style" you will get the dialog box that has Font Name and change to Arial Narrow. Room finish Schedule may be achieved by using Tables, and you can use Fields in the tables that access other text or information in the drawing. Not sure if that's what you're looking for. Quote
