demetre Posted August 31, 2010 Posted August 31, 2010 I am currently using Autocad LT 2006 and have trouble with maintaining correct OLE object proportions when importing into Autocad. Essentially I am copying and pasting a jpeg file (ie a land survey) from Photoshop into Autocad. However when I do so and then scale a portion of the image to its known dimension (ie a property line) the image never scales proportionally - I think this is not do to the scaling function but when the image is pasted it pastes slightly off proportion. For instance I can copy and paste an image of a 25'x25' square and when pasted into autocad one of the sides of the square is slightly larger than the other. I have tried the same copy and paste on a 30 day trial of Autocad 2011 and do not get the same problem. Does anyone have any input on this problem for such an older version of Autocad? Quote
demetre Posted August 31, 2010 Author Posted August 31, 2010 Thru trial and erros I think I just figured out how to paste and scale to maintain proper proportions. I have no clue why this works and other methods do not. I selected and copied the image in photoshop and did a paste special as a bitmap in Autocad. This for some reason is the only way to paste while maintaining proportions. Then in order to scale it while maintaining proportions I had to grab one grip on a corner to scale it a little bigger. After doing this scale once I can then use the scale command to scale it to a known dimension. Only then do I have a scaled and proportioned drawing. Again I have no clue why this works and others methods do not. Quote
