Greeting everyone,
Below is a layer color changing lisp that I use alot. I was wondering if someone could help me modify it to ignore locked layers. Any help would be greatly appreciated!
Thanks
(defun c:cdwg ()
    (command "chprop" "all" "" "c" "bylayer"  "")
    (command "-layer" "c" 8 "*" "c" 8 "0" "c" 8 "defpoints" "")
      (setq tbl(tblnext "LAYER" T))
      (while (/= tbl nil)
        (setq layName(cdr(assoc 2 tbl)))
        (if(wcmatch layName "*wall*")
          (command "-layer" "C" 4 layName "")
        (if(wcmatch layName "*WALL*")
        (if(wcmatch layName "*Wall*")
        (if(wcmatch layName "*door*")
        (if(wcmatch layName "*DOOR*")
        (if(wcmatch layName "*Door*")
        (if(wcmatch layName "*glaz*")
        (if(wcmatch layName "*GLAZ*")
        (if(wcmatch layName "*Glaz*")
        (if(wcmatch layName "*glass*")
        (if(wcmatch layName "*GLASS*")
        (if(wcmatch layName "*Glass*")
        (if(wcmatch layName "*window*")
        (if(wcmatch layName "*WINDOW*")
        (if(wcmatch layName "*Window*")
        (if(wcmatch layName "0")
          (command "-layer" "C" 7 layName "")
   (command "layer" "s" 0 "")
   (command "purge" "a" "*" "n")
   (command "regen")
   (command "zoom" "e")
My two cents...
(defun c:CDWG (/ oldCmdecho layerTable layerName layerColor)
 (vl-load-com)
 (cond
   (*activeDoc*)
   ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))
 (vla-startundomark *activeDoc*)
 (vla-purgeall *activeDoc*)
 (if (/= 0 (setq oldCmdecho (getvar 'cmdecho)))
   (setvar 'cmdecho 0))
 (vl-cmdf "._chprop" "all" "" "color" "bylayer" "")
 (if (setq layerTable (vla-get-layers *activeDoc*))
   (vlax-for x  layerTable
 (if (and (setq layerName (strcase (vla-get-name x)))
          (= :vlax-false (vla-get-lock x)))
     (cond
       ((vl-position
           layerName
           (list "*DOOR*" "*GLASS*" "*GLAZ*" "*WALL*" "*WINDOW*"))
        (setq layerColor 4))
       ((= "0" layerName) (setq layerColor 7))
       (T (setq layerColor ))
     (vla-put-color x layerColor)))))
 (vla-zoomextents (vla-get-application *activeDoc*))
 (setvar 'cmdecho oldCmdecho)
 (terpri)
 (prompt "\nLayer Settings Complete. ")
 (terpri)
 (vla-endundomark *activeDoc*)
 (princ)) ;_end defun
Edited by BlackBox
thanks Render.....it semi works. It changes everything to color 8 except for the locked layers, but it doesn't changes the list items to color 4. any suggestions?
My mistake :oops: , let's try this revision:
 (vl-load-com)
 (cond
   (*activeDoc*)
     (cond
       ([color=blue]([color=red]wcmatch[/color] layerName "*DOOR*,*GLASS*,*GLAZ*,*WALL*,*WINDOW*")[/color]
 (terpri)
 (terpri)
