Electrical Conduit question - Please Help
I'm running Autocad Mep 2011...I am installing conduit and want to change the radius of the conduit elbows.....I did select the elbow, right clicked, went to its properties where I was able to change the radius but it would only allow me to go bigger....It says "the selected radius of curvature is less than the minimum size allowed for this part. Please enter a larger radius value or select a different nominal size"....Is there a way to make it a tighter bend radius?...Please Help
  • 4 weeks later...
you are stuck with the standard bend radii's of 15, 30 60 and 90 degree. to beat it you'll have to sweep a circle or something equal to fake it in there
