pvd Posted September 2, 2010 Posted September 2, 2010 Hi all, I tried to right-click on the command (I-icon - Save as - Save as), usually that's the way I add icons to my quick acces toolbar but that doesn't seem to work here, nor dragging. Any suggestions? Thanks! Quote
ReMark Posted September 2, 2010 Posted September 2, 2010 I believe it has to be done via the Customize User Interface Editor. At least that is the way it was done in generic AutoCAD 2010. Quote
ReMark Posted September 2, 2010 Posted September 2, 2010 In the CUI click the plus sign (+) next to the Quick Access Toolbars node to expand it. It should read Quick Access Toolbar 1. In the Command List Pane scroll down and find the Save As command. Drag the command up to add it to the QAT. The splitter bar (black line) indicates the location where the command will be added. Select your location and release the hold on the command. Click on the Apply button at the bottom right hand corner. You're done. Quote
jdits7 Posted September 2, 2010 Posted September 2, 2010 If you right click to the side of the ribbon you will get a menu, go to Customize User Commands. In the left hand column find save as, click on it and select add, it will add it to the right hand column, hit apply and then close. By doing this it will add a user commands panel to your ribbon. Then right click on the button it adds and select Add to Quick Access Toolbar and it will appear on your QAT. Then so you don't have the extra panel on your ribbon, you can shut that panel off. Hope this helps. Quote
ReMark Posted September 2, 2010 Posted September 2, 2010 jdits7: Can you confirm that the method you outlined above works in 2010? I know that generic AutoCAD 2010 and 2011 differ in their approach. Quote
jdits7 Posted September 2, 2010 Posted September 2, 2010 Yes, it is the same method from 2010 to 2011. Quote
ReMark Posted September 2, 2010 Posted September 2, 2010 (edited) In generic AutoCAD 2011 "Save As" is included on the QAT as one the default choices. Never mind. I obviously missed something. I was lost...now I'm found. Thanks. Edited September 2, 2010 by ReMark Quote
pvd Posted September 2, 2010 Author Posted September 2, 2010 thanks Jdits, I managed following your instructions. Thanks Remark for support! Quote
