michaeloureiro Posted September 11, 2008 Posted September 11, 2008 Some layouts don´t print when i try to publish a set of layouts. how can i fix this? thanks Quote
sab423 Posted September 11, 2008 Posted September 11, 2008 Can you give a little more detail? Are you printing layouts from the same file or multiple files? Do you have default page setups for the layouts? Quote
BOB'27T Posted September 11, 2008 Posted September 11, 2008 Check the page setup and make sure they're all set to the same plotter. Quote
michaeloureiro Posted September 12, 2008 Author Posted September 12, 2008 I´m printing from the same file and the print previews come out fine, but when i publish the work, the borders and everything i set up in layout space doesn´t print or comes out incomplete... Quote
sab423 Posted September 12, 2008 Posted September 12, 2008 Also check the sheet size you have selected and you may need to use a different selection. If your using ARCH and your paper is ANSI then your going to have a size issue. The preview will look fine, but the out put will not. Quote
michaeloureiro Posted September 14, 2008 Author Posted September 14, 2008 it doesn´t seem to be a paper configuration problem, coud it have to do with computer or plotter memory capacity? I´m plotting on a hp 500 Quote
sab423 Posted September 15, 2008 Posted September 15, 2008 It sounds more like a settings issue. Quote
