Mapcar + lambda Description
Sweety
Hello GUYS.:)
I just wanted to show you something, which means a big step to me with Defun + Lambda functions in this example. :lol:
As it is mentioned in the uploaded book by Renderman as follows .
[size=3](setq pt1 '(-3.24 2.82 0.0))[/size]
[size=3](setq pt2 '(2.5 8.76))[/size]
[size=3](mapcar '(lambda (c1 c2)[/size]
[size=3]         (/ (+ c1 c2) 2.0)[/size]
[size=3]         )[/size]
[size=3]    pt1[/size]
[size=3]    pt2[/size]
[size=3])[/size]
[size=3]that wouls return the mid point between both of them.[/size]
BUT, in my example also would return the same result with use of Defun .
Check this out PLEASE. ....
(defun mids (sweet1 sweet2)
 (list
   (setq one (/ (+ (car sweet1)(car sweet2)) 2.0))
   (setq two (/ (+ (cadr sweet1)(cadr sweet2)) 2.0))
    (setq three (/ (+ (caddr sweet1)(caddr sweet2)) 2.0))
(setq p1 '(1.0 2.0 3.0))
(setq p2 '(4.0 5.0 6.0))
(mids p1 p2)
Hope you give me your opinion about them.
Thanks for all
  • Replies 22
  • Sweety
    10
  • Lee Mac
    8
  • BlackBox
    4
  • muthu123
    1
So you can see the benefit in terms of concision and elegance by using a mapcar expression :)
Check out my earlier post also, it has quite a few examples of averages of points.
Thank you Lee.
I am so happy with it today, cause I have been forcing my self between Mapcar + Lambda for so long for now, and finally
got it with Defun function. :lol:
So Mapcar and Lambda are really doing a very great work togather, Specially when we want lots of devides and distributions for vaiables.
Hope you do not mind if I discovered something else to share opinions with it. :)
Thanks a lot
