sadhu Posted September 7, 2010 Posted September 7, 2010 I'm using the lisp below to convert time in seconds to the format (hour : min: sec) but sometimes I get negative value error. I'm sure there is a better lisp around. All help is appreciated. (defun tempo (seconds) ;;;(setq seconds 3666.) (setq ore (/ seconds 3600.)) (setq oret (rtos ore 2 6)) (setq oretlen (strlen oret)) ;;;(setq orelen (strlen ore)) (setq oret_p (substr oret 1 (- oretlen 7))) (setq minuti (substr oret (- oretlen 6) 6)) (setq minuti (* (atof minuti) 60.)) (setq minuti (rtos minuti 2 6)) (setq minlen (strlen minuti)) (setq min_p (substr minuti 1 (- minlen 7))) ;////////////////// (setq sec (substr minuti (- minlen 6) 6)) (setq sec (* (atof sec) 60.)) (setq sec (rtos sec 2 6)) (setq seclen (strlen sec)) (setq sec_p (substr sec 1 (- seclen 7))) [color=red](setq tmp_result (strcat oret_p " h " min_p " m " sec_p " s"))[/color] ;;;(princ tmp_result)(princ) );defun Quote
jammie Posted September 7, 2010 Posted September 7, 2010 (edited) Had to look up a bit about menucmd & edtime in the AutoCAD developers file but maybe something like this could be useful (menucmd "M=$(edtime,$(getvar,date), H:MM:SS)") Regards Jammie Edited September 7, 2010 by jammie Ignore reply, misunderstood original request Quote
Lee Mac Posted September 7, 2010 Posted September 7, 2010 Quick one, not too elegant (defun FormatSeconds ( sec ) ( (lambda ( s ) (strcat (itoa (/ s 3600)) "h " (itoa (/ (rem s 3600) 60)) "m " (itoa (rem (rem s 3600) 60)) "s " ) ) (fix sec) ) ) Assumes integer argument. Quote
lpseifert Posted September 7, 2010 Posted September 7, 2010 (edited) another quickey... even less elegant (setq ts (getreal "\nEnter total seconds: ") hrs (/ ts 3600.) rem1 (rem ts 3600. ) mins (/ rem1 60.) rem2 (rem mins 1.) secs (* rem2 60.) ) (princ (strcat (rtos hrs 2 0) " hrs : " (rtos mins 2 0) " mins : " (rtos secs 2 2) " secs")) Edited September 7, 2010 by lpseifert fixed math Quote
sadhu Posted September 7, 2010 Author Posted September 7, 2010 Thanks lpseifert Thanks Lee, Very elegant indeed - and better still - it does my case. I tried both though my seconds input is a real number. Quote
Lee Mac Posted September 7, 2010 Posted September 7, 2010 Thanks lpseifertThanks Lee, Very elegant indeed - and better still - it does my case. I tried both though my seconds input is a real number. Mine allows a REAL input, but will convert this straight to an INT, I shall have a rethink on my function... Quote
Lee Mac Posted September 7, 2010 Posted September 7, 2010 Hows this: (defun LM:FormatSeconds ( s l ) ;; © Lee Mac 2010 (if l (cons (fix (/ s (car l))) (LM:FormatSeconds (rem s (car l)) (cdr l)) ) ) ) (defun test ( seconds ) (apply 'strcat (mapcar 'strcat (mapcar 'itoa (LM:FormatSeconds seconds '(3600.0 60.0 1.0 0.001)) ) '("h " "m " "s " "ms") ) ) ) Will format to any level, provided that you supply the multipliers Quote
David Bethel Posted September 7, 2010 Posted September 7, 2010 Maybe add a little formating: [b][color=BLACK]([/color][/b]setq sec [b][color=FUCHSIA]([/color][/b]getreal [color=#2f4f4f]"\nSeconds: "[/color][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]setq hrs [b][color=FUCHSIA]([/color][/b]fix [b][color=NAVY]([/color][/b]/ sec 3600.[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] min [b][color=FUCHSIA]([/color][/b]fix [b][color=NAVY]([/color][/b]/ [b][color=MAROON]([/color][/b]rem sec 3600[b][color=MAROON])[/color][/b] 60[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] sec [b][color=FUCHSIA]([/color][/b]rem sec 60[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]princ [b][color=FUCHSIA]([/color][/b]strcat [color=#2f4f4f]"\n"[/color] [b][color=NAVY]([/color][/b]itoa hrs[b][color=NAVY])[/color][/b] [color=#2f4f4f]":"[/color] [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]< min 10[b][color=MAROON])[/color][/b] [color=#2f4f4f]"0"[/color] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]itoa min[b][color=NAVY])[/color][/b] [color=#2f4f4f]":"[/color] [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]< sec 10[b][color=MAROON])[/color][/b] [color=#2f4f4f]"0"[/color] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]rtos sec 2 4[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
