MarcoW Posted September 8, 2010 Posted September 8, 2010 Hello everyone, As the title says, in some drawings the Plot Preview takes a long time. In case of a nearly empty drawing it is less then a second. In a regular one it maybe 2 seconds, and some big drawings, with a lot of Xrefs etc. take 10 seconds to get to the full preview. Well of course I can understand that the more objects in a drawing I have the more there must be regenerated, the image needs to be build up. This is why I tend not to create too heavy drawings: I split them up, like the ground floor is a seperate drawing than the first floor. However tis cannot be done not allways and in those cases I end up with a too big drawing. Besides the plot preview, the switching between layouts also takes more time. Espescially when there are several viewports per layout. Again: it is clear to me that AutoCAD needs time to do things and the more objects, the more time. But maybe there are tips / functions that can improve the time needed for things. If so, please share and I will be very thankful. If not: then I will live with it and go on as usual. Thanks in advance for the effort (and reading this thread). Quote
ReMark Posted September 8, 2010 Posted September 8, 2010 Could the root cause of your problem be hardware related? Quote
MarcoW Posted September 8, 2010 Author Posted September 8, 2010 Hi ReMark, Hmm... I never say never, but my idea is that I have a great machine to work with. It's specs: Pentium Dual Core E5300 2.6GHz + 4Gb ddrRam + VideoCard Asus X1650 256MB. I never have problems with my machine but as said... never say never.... Quote
Pablo Ferral Posted September 9, 2010 Posted September 9, 2010 ...or network related... Autocad can slow down when plotting if it can't 'find' the plotter. ...or page file related... Have a look in the options dialog to see where your plotting page file is. It could need a clean out or moving... Quote
MarcoW Posted September 9, 2010 Author Posted September 9, 2010 ...or network related... Autocad can slow down when plotting if it can't 'find' the plotter. ...or page file related... Have a look in the options dialog to see where your plotting page file is. It could need a clean out or moving... Thanks Pablo I will check it out. Any result I will post. Quote
ReMark Posted September 9, 2010 Posted September 9, 2010 What OS are you running? Could it be you have a bloated scalelist? How about too many layer filters? Quote
