Hi
I am looking of a way to make af reference between attributes.
I have a lot of attributes that has to have the same value but the value is a variable......
Is there a way I can chance one attribute so the rest follows that value?
Stefan
not easilly - there are workarounds but I haven't found one worth the effort. Look through the "similar threads" listed below.
can you try usning 'field'?
Yes, FIELDS could be a solution. You can have a number of fields all linked to a single string of text. If the master text is changed, all the fields update. Attributes can be set up as FIELDS or they can simply exist as stand-alones inside a block.
If you do experiment with fields, make sure you REGEN to activate the changes.
Thank's for the answers.
I solved my problem by using Field:).
Best regards
Stefan
  • 2 weeks later...
hi Stefan,
can you share your solution to your problem ?
