RONK Posted September 10, 2010 Posted September 10, 2010 (edited) How do i flatten a sheetmetal part in INVENTOR? Problem is that i used the flatten command to flatten the part. Then I did the drawing in Inventor. When I saved it, in the sheet metal module, inventor grayed out the flatten icon. How do i ungray it to be able to fltten the part again. cadtotor is not allowing me to upload .ipt file rk1.zip Edited September 11, 2010 by RONK added sheetmetal part file Quote
jdits7 Posted September 10, 2010 Posted September 10, 2010 Include the file and I might be able to help. Quote
Lazer Posted September 12, 2010 Posted September 12, 2010 The file you have attached (the box with no lid) has no problem? I pressed the flat pattern and it worked no problem. Edit, post a screen shot of what the problem is so we can have a look. Quote
kencaz Posted September 13, 2010 Posted September 13, 2010 When I saved it, in the sheetmetal module, inventor grayed out the flatten icon. How do i ungray it to be able to flatten the part again. It's grayed out because you already created it. Just right click "Edit Flat Pattern" in your Browser Tree, and it should return. Right click "Edit Folded" to return... KC Quote
