Handy Man Dan Posted September 14, 2010 Posted September 14, 2010 Hi, all I want to do is change scale on a particular axis instead of uniform. Can anyone help, please? This is doing my head in... Quote
dbroada Posted September 14, 2010 Posted September 14, 2010 there is no direct way to do this. The work around is to make your items into a block, scale that using the properties palette then explode it. Quote
RobDraw Posted September 14, 2010 Posted September 14, 2010 (edited) In the properties box, you can set the scale for each of the axes. Edit: for blocks. Edited September 14, 2010 by RobDraw Oops Quote
ReMark Posted September 14, 2010 Posted September 14, 2010 Try this link. Find and read the part about scaling with lisp utility. http://wheeqo.web.id/tutorial/non-uniform-scale-on-autocad Quote
Handy Man Dan Posted September 15, 2010 Author Posted September 15, 2010 Thanks gents, I'll check it out :wink: Quote
