ko31505 Posted September 15, 2010 Posted September 15, 2010 I posted a new .dwt file on the network today and threw in the default wdl file today but as other users on the network try and use it the labeling on the project properties reverts back to "line 1", "Line 2" etc from the labels I had created. does anyone know why this is happening? How do I ensure the wdl file in the folder goes along with the title block I had created to use it. Thanks Quote
ReMark Posted September 15, 2010 Posted September 15, 2010 Just to confirm, are the dwt and wdl files both in the same folder? Quote
ko31505 Posted September 15, 2010 Author Posted September 15, 2010 Yes, the default_wdtitle.WDL file and the .dwt file are in the same folder Quote
ReMark Posted September 15, 2010 Posted September 15, 2010 And that folder is the main project folder right? Did you check to see if there is another default_wdtitle.wdl file somewhere on the network or maybe on their own computers? Quote
ko31505 Posted September 15, 2010 Author Posted September 15, 2010 The files are in the same folder. Where would the WDL default file be kept on the machine locally? Quote
ReMark Posted September 15, 2010 Posted September 15, 2010 Not sure. Did you check the network to see if there were any other wdl files lurking about? Quote
ko31505 Posted September 17, 2010 Author Posted September 17, 2010 Is there a way to link that specific title block with a specific wdl file and throw it right into the dircetory with the .dwt file? Quote
MarkFlayler Posted September 20, 2010 Posted September 20, 2010 Well you are all kinda wrong here if the WDL is not in an Electrical Support directory and you have not setup your environment file correctly. Just because the DWT and the WDL are in the same directory does not make it a support path for Electrical. Quote
MarkFlayler Posted September 20, 2010 Posted September 20, 2010 Is your license system network FlexNET? Yes: Did you deploy and setup shared network libraries and support paths? No: Did you modify your environment file and/or create a master project to copy from each time? Is your license system standalone and on subscription? Yes: You will have to modify your environment file or if you are subscription you can get a Multiseat Standalone single SN and deploy that with the deployment wizard to create the correct ENV file. No, I am not on subscription: You must either rethink you file structure, create a script to write out to the users, modify your ENV file, or get on subscription and redeploy. Quote
ko31505 Posted September 22, 2010 Author Posted September 22, 2010 The license is a network one and the env file is on the network, I cannot find the wdl file. If it were a locale install as IT has done on several occasions where would I locate it? Thanks Bill EE Quote
MarkFlayler Posted September 22, 2010 Posted September 22, 2010 There is NO default wdl file with the software. It will simply search the support directory until it finds the first one in the search order. Customize LINEx labels The generic LINEx labels in the various title block and project description dialog boxes can be customized. Use any generic text editor such as Notepad or WordPad to create one of the following files: _wdtitle.wdl - where matches the name of the active project. Save the file in the same folder as the project WDT file. default_wdtitle.wdl - save the file in the same folder as the project WDT file. default_wdtitle.wdl - save the file in a folder in the AutoCAD Electrical search sequence. [*]The file contains one line per label in the format LINEx=label. The entries do not have to be in order and line numbers can be skipped. LINE1 = Project Title 1 LINE2 =Title 2 LINE3 = Title 3 LINE4 = Project Number LINE5 = Date LINE6 = Engineer LINE7 = Drawn By LINE8 = Checked By LINE9 = Scale [*]Save and exit the text file. [*]Open AutoCAD Electrical and test. Search sequence for .wdl files You can create different WDL files for different projects. The search sequence is as follows: Look in the same folder as the .WDP file for the project, for a file called _WDTITLE.WDL where matches the name of the active project. Look in the same folder as the .WDP file for the project for a file called DEFAULT_WDTITLE.WDL. If WD_ACADPATHFIRST flag is present in wd.env file, look for DEFAULT_WDTITLE.WDL in ACAD paths. Look for DEFAULT_WDTITLE.WDL in the AutoCAD Electrical USER folder. Look for DEFAULT_WDTITLE.WDL in the base AutoCAD Electrical folder. If WD_SUP_ALT is defined in the wd.env file, look for DEFAULT_WDTITLE.WDL in the specified path. Look for DEFAULT_WDTITLE.WDL in ACAD paths (if WD_ACADPATHFIRST flag is not set in the wd.env). Quote
MarkFlayler Posted September 22, 2010 Posted September 22, 2010 You could also be in a world of hurt with sharing any real project or mapping files if IT installs some as Standalone and other as Network. If ACADe is installed Standalone then it will not look to the network for an env file. Quote
