lostincad Posted September 16, 2010 Posted September 16, 2010 Hey guys I'm about to start working on a project. My boss sent me an AutoCAD floor plan. However it's in inches. I've used the dimension tool to see how big the drawing is and it's in inches. How do i convert it back to MM? Many thanks Tara Quote
ReMark Posted September 16, 2010 Posted September 16, 2010 To convert inches to millimeters, multiply the number of inches by 25.4 and make sure to set your units to decimal. Quote
lostincad Posted September 16, 2010 Author Posted September 16, 2010 To convert inches to millimeters, multiply the number of inches by 25.4 and make sure to set your units to decimal. Hey there ReMark, thank you for helping out again [= aww i was hoping there would be an easier way to do it.. like select all the lines and change the options.. somehow.. i know i'm living in fairy land *sighs* Quote
JD Mather Posted September 16, 2010 Posted September 16, 2010 an easier way to do it.. like select all the lines and change the options.. . Sounds like your describing Scale to me? Quote
lostincad Posted September 16, 2010 Author Posted September 16, 2010 Sounds like your describing Scale to me? yes sorry i failed to mention that. Basically the drawing was done in the US, so it's all in inches. My brain doesn't process inches. I only know how to work with millimeters on autocad and as it's a big project i really don't want sit here and work out what the dimension of every line is. any tips on how to make this any easier? Thank you Quote
lostincad Posted September 16, 2010 Author Posted September 16, 2010 To convert inches to millimeters, multiply the number of inches by 25.4 and make sure to set your units to decimal. sorry to bother you again...i'm still unsure how to do this... for example.. i have a line which is 488'' so to work it out i have to go ... 488*25.4= 12395.2 so that's like.. 12metres 395mm ? is that correct? Thanks Quote
Oppie Posted September 16, 2010 Posted September 16, 2010 (edited) sorry to bother you again...i'm still unsure how to do this...for example.. i have a line which is 488'' so to work it out i have to go ... 488*25.4= 12395.2 so that's like.. 12metres 395mm ? is that correct? Thanks Hi lostincad, I think ReMark meens that you use the command SCALE then select everything in the drwaing and type the scale 25.4 and it blows the whole drawing op till 25.4 times bigger. Edited September 16, 2010 by Oppie Quote
lostincad Posted September 16, 2010 Author Posted September 16, 2010 Hi lostincad, I think ReMark meens that you use the command SCALE then select everything in the drwaing and type the scale 25.4 and it blows the whole drwaing op till 25.4 times bigger. omg.. i feel so retarded. You are a life saver! well thank you for explaining that, it worked! can i ask you something please... the dimension tool seems to work in inches for some reason. any ideas on how to fix that? Quote
Oppie Posted September 16, 2010 Posted September 16, 2010 just type the command UNITS then choose in chapter lenght decimal and insertion scale milimeters Quote
lostincad Posted September 16, 2010 Author Posted September 16, 2010 just type the command UNITS then choose in chapter lenght decimal and insertion scale milimeters Thank you so much [= it seems to work fine now Have a lovely day Quote
cadvision Posted September 20, 2010 Posted September 20, 2010 Scale all (make sure all layers are thawed) x 25.4. Use 0,0 as ref point. Then do zoom extents. Now you will be working in "mm". Other option to start a new drawing using your standard metric DWT and xref or insert the US drawing into your new drawing and scale 25.4 Quote
