cameroon95 Posted September 12, 2008 Posted September 12, 2008 Hi guys, iv been tyring to import dwg files in sketchup but im coming across problems when trying to manuvere around the drawing. Sketchup just seems to operate very slowly, to the point that it is unworkable. However on my boss's computer the drawings work fine on his version of sketchup. What could be causing this? I should point out that he is using sketchup pro and I am using the normal version, would this make a difference? I should also state that my pc is newer than his so i isn't an issue of performance. Thanks Quote
JBullseye74 Posted September 12, 2008 Posted September 12, 2008 I find its best to bring in a couple of items at one time from AutoCAD and then turn them into solids and make into Groups OR Componants. Rather than loads at once. Also try to Overkill your lines in Autocad to make sure your not bringing in multiple lines over each other. Think there is also a script in sketchup which you can download which does this. Quote
cameroon95 Posted September 12, 2008 Author Posted September 12, 2008 I dont own autocad, I only get given the files you see. Any ideas on where i can get the script buddy? or what it is called? Quote
JBullseye74 Posted September 12, 2008 Posted September 12, 2008 Probably one of these free ones on here: http://www.smustard.com/scripts/ Quote
