How to specify a tangent line at an angle
What is the procedure used to insert a line, tangent to a circle , at a specific angle.
Thanking you is,
Reggy
unlikely to be best way but as no replies:
draw line at the angle you want
move from midpoint to centre of circle
trim / extend line so ends snap to cirle (you now have circle cut exactly in half)
copy line and rotate 90 degrees (now cirle cut in 4)
move original line from midpint to endpoint of second line
done.
probably you knew this..... sorry!
Start the Line command. When AutoCAD asks for the first point, enter TAN and click the circle somewhere about the start of the line. When prompted for the second point, enter something like @100
that was the post i should have made......nice one, thanks!
