change the length of tail of arrow
hi,all
in autocad 2010,I can not find the setting for the tail length of arrow in dimstyle option,see picture below:
dose anyone know how to change the lengh????thanks.
The only thing I can find without any programming technique is that the minimum length of the 'tail' is the same as the length of the arrow itself
@NBC
if "using" programming,witch variable should I set???
(command "whichvariable"  value)
thanks.
I personally do not know the answer.
Hopefully somebody on here will though, as it is something I have often wondered.
there are a few options avaiable to you but it would depend on what information you actually require. if you look in the dimension settings standards for your dimension style you can suppress these lines and arrows or you can allow certain perramiters to allow only if the text will not fit to not allow the arrows and the lines you are looking at to be shown outside the dimension line. if i could post a picture of a screen shot i would but i dont have the abilty to post pictures yet.
any links posted by a user with under 10 posts will automatically wind up awaiting moderator approval, so will not appear instantly
  • 2 weeks later...
@da mac
hi,you can use outside Image host
upload your picture in this site http://photobucket.com/
then post the website of the picture your want to show here
i would but since i have been demoted from my office job i dont have access to autocad at the moment as soon as i get back in the office i will link it for you although by then you may have fount the answer. all i can say is just take a look at all the options available to you when setting up a dimension style and this should solve your problem the options are on one of the last tabs in dimensions styles
