Can someone write me a lisp that would use the quick select command using to select everything on layer STR-TXT using window select. I use this SO much at work and it would save a great deal of time. I've tried for 3 hours but I think this is beyond me. Thank you for any help!
try
(ssget '((8 . "STR-TXT")))
(defun c:test (/ ss)
 (if (setq ss (ssget '((8 . "STR-TXT"))))
   (command "_.copy" ss "" pause)
   (prompt "\nNo objects selected")
I would prefer it this way .
(sssetfirst nil '(ssget "_x" '((8 . "STR-TXT"))))
Tharwat
And why is that? Just curious.
SO CLOSE..IT RECOGNIZES THE STR-TEXT LAYER THOUGH IT'S TELLING ME HOW MANY ENTITIES THERE ARE WITHOUT ACTUALLY SELECTING THEM..THANKS LT. DAN.."I'M NOT A SMART MAN"
(defun c:QS (/ SS)
what are you trying to accomplish with the objects?
TRYING REMARK AND THARWAT313 CODE POPS UP
bad argument type: lselsetp (SSGET "_x" (QUOTE ((8 . "STR-TXT")))); error: An
error has occurred inside the *error* functionAutoCAD variable setting
rejected: "cmdecho" nil
DO I HAVE A SETTING WRONG..TRIED CMDECHO 1?? SORRY NEWB ON THE FORUMN
I use the quick select layer all day long .. Just a basic quick select..layer..str-txt..this is just a starting point..hopefully i can evolve from here
try this
   (command "_.copy" ss "" pause pause)
does this work?
updated! sorry about that. try again
My two cents...
(defun c:FOO (/ ss count)
 (if (setq ss (ssget "_x" '((8 . "STR-TXT"))))
     (sssetfirst nil ss)
     (prompt
       (strcat
         "\n  >>  "
         (cond
           ((= 1 (setq count (sslength ss)))
            (strcat "1 Object"))
           ((< 1 count)
            (strcat (rtos count 2 0) " Objects")))
         " Selected ")))
   (prompt "\n  <!>  No Objects Selected  <!> "))
 (princ))
I am sorry, it should not be with quote after nil.
Here it goes
(sssetfirst nil (ssget "_x" '((8 . "STR-TXT"))))
Remark, this code would select all entities that included within Layer "STR-TXT" and the user would see the selection set
in a dwg.
Thanks
That seems just to select all the selected entities...any other suggestions?
(defun c:Test (/ ss)
 (sssetfirst nil (setq ss (ssget '((8 . "STR-TXT")))))
Sorry! Lt dan that worked perfect! Thank you! Also for the entire drawing (which i'll definitely need) renderman's code worked great. Thank you so much! Wish i asked 3 hrs ago!
