jake77777 Posted September 24, 2010 Share Posted September 24, 2010 My question is, is there a way to disable the popup text window from appearing when loading the lisp files as it's very annoying.My question is, is there a way to disable the popup text window from appearing as it's very annoying and un-needed. I came across the following code and it supposedly worked for someone. When I add that as another lisp to my lisp files to automatically load it, it does minimize it for the first drawing opened but appears on all future drawings opened. Hopefully a quick fix. Any help is appreciated. (defun C:NewList () (command "._List") (while (> (getvar "CMDACTIVE") 0) (command pause) ) (graphscr) (princ) ) Quote Link to comment Share on other sites More sharing options...
StevJ Posted September 24, 2010 Share Posted September 24, 2010 Are any of those lisps you load running the command "-UNITS" ? SteveJ Quote Link to comment Share on other sites More sharing options...
jake77777 Posted September 24, 2010 Author Share Posted September 24, 2010 There were no units string though I came across textscrn in one of them.. All along I thought it was normal for a popup box. Thanks your comment helped narrow in on the problem! Quote Link to comment Share on other sites More sharing options...
StevJ Posted September 24, 2010 Share Posted September 24, 2010 You're welcome. Yep. TEXTSCR will do it, too. SteveJ Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 24, 2010 Share Posted September 24, 2010 This will make selection a lot easier... (defun c:Test (/ ss) (if (setq ss (ssget)) (progn (command "_.list" ss "") (graphscr) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
