I am looking for a lisp routine to list the length of a line or a polyline to ascii.
thanks in advance
Should be something around here to meet yours needs. Listing line lengths has been a favorite request. Have you tried a search yet?
Just a suggestion. In the future it might helpful if your thread title was a bit more descriptive of the problem you wish help with. Thanks mate.
Well Lt Dan,
When listing a line the text window lists all the properties of the line and I only want the length of the line. there are many lines that need their extraction of their lengh. Hence the request of length to ascii.
I hope this will work for u
(setq obj (car(entsel)))
(setq vlobj (vlax-ename->vla-object obj))
(setq ln (vlax-get-property vlobj 'length))
(defun AT:Length (ent)
 ;; Return length of curve
 ;; Alan J. Thompson, 08.06.09
 (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent))
Returns the length of any curve.
Well not quite I am looking to list a number of lines in Autocad and list them by their lengths to an ascii file.
The Lisp program LST will put -among other information- the length of the lines found in the drawing in a text file.
