Hi guys, I modified my distance command (shown below). However it doesn't show the snap highlights (nea, per) that I got used to seeing. Though it provides correct distance result, maybe it's just more on "aesthetic & feel" that I'm after.. what should I add in here? Thanks!
(DEFUN C : D ()
(COMMAND "DIST" "NEA" pause "PER")
should be no space between "c : d"
try this
(DEFUN C:D ()
kruuger
try this
(defun c:d ()
 (setq oldsnap (getvar "osmode"))
 (setvar "osmode" 640)
 (command "dist" pause pause)
 (setvar "osmode" oldsnap)
You can not name your routine with ( D ) because it is already given to the command DIMSTYLE .
we can do this but we overwirte DIMSTYLE shortcut. everything depends on our pgp file.
i also prefer D for distance:)
kruuger
kruuger
That's what I wanted to indicate to . :)
Good Luck kruuger
Tharwat
If you are unsure what your cmdecho will be set to, you could do something like this (I set mine to 0 in the startup):
(defun c:D (/ *error* cmd)
 (defun *error* (msg)
   (and cmd (setvar 'cmdecho cmd))
   (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
 (setq cmd (getvar 'cmdecho))
 (setvar 'cmdecho 0)
 (princ "\nSpecify first point: ")
 (command "_.dist" "_near" PAUSE)
 (setvar 'cmdecho 1)
 (while (eq 1 (logand 1 (getvar 'cmdactive))) (command "_per" PAUSE))
 (*error* nil)
If you know cmdecho will be set to 1, you could just use this:
(defun c:D (/)
BTW, Tharwat, there is no issue with defining LISP routines as a defined PGP shortcut, it's only a true command (eg. you would have trouble trying to call this "DIST").
I also prefer "D", but I abandoned the use of DIST long ago and wrote my own (much more robust) DistanceInquiry.LSP.
Actually, the following works fine for me. It snaps properly and displays the Nearest and Perpendicular OSnap markers.
(defun c:D (/) (command "_.dist" "_near" PAUSE "_per") (princ))
try this
(defun c:d ()
Hi lpseifert, thanks, it worked for me :)
Thanks for the advice kruuger. I decided to separate it cause a smiley appears hehe like this :D
Thanks Tharwat, I got your point. I guess the lisp in our office had been modified already that's why maybe some commands including dimstyle was not affected. I saw they assigned a DI alias to it.
Hi guys, thanks for all the reply and suggestions. I tried all, though lpseifert's worked fine with my system. Maybe it's a CAD version issue. Thanks again, you're great!
