sanderson Posted September 27, 2010 Posted September 27, 2010 I installed the VBA support files. I have both 32-bit and 64-bit installations. For some reason, the 32-bit install cannot find the AutoCAD 2010 type library (64-bit works great!!!). I believe it is located here for both install types (by default): C:\Program Files\Common Files\Autodesk Shared\acax18enu.tlb. I've tried unloading and reloading by browing to this file, and the display still says it is missing. Please help, and thank you in advance. Quote
