Trisha Posted September 28, 2010 Posted September 28, 2010 I have a dwg-file that containes 15 drawings ( sheet 1 to 15) I want a single dwg-file for each sheet. Is it possible to spilt up the dwg-file in a easy and fast way? Quote
ReMark Posted September 28, 2010 Posted September 28, 2010 You might try WBlocking out each sheet. Quote
Jimmy Tin Posted September 28, 2010 Posted September 28, 2010 Trisha if you go to the link below there is a lisp that will convert multiple layouts to multiple drawings. I have not tested the lisp so possibly make a copy of the drawing just in case. http://www.jtbworld.com/lisp/layoutstodwgs.htm Quote
mdbdesign Posted October 12, 2010 Posted October 12, 2010 Trisha if you go to the link below there is a lisp that will convert multiple layouts to multiple drawings. I have not tested the lisp so possibly make a copy of the drawing just in case. http://www.jtbworld.com/lisp/layoutstodwgs.htm Tested on 2010 and work. Quote
