AutoCAD 2011Open drawing tab.
Is there a way to reverse the tab order of the open drawings when multiple drawings are open or is there a built in function that will display drawing tabs for the current open drawings?
In an older version of CAD I remember installing a third party app that allowed/showed a tab for each open drawings.
Thanks,
Robert J
DWGMan is a 3rd party app that display tabs. Don't know if you can rearrange the tabs though, don't have it anymore since Quick View Drawings came along. And the bigger question is, why would you want to rearrange the tabs?
When I open a set of drawing, say for example there are 15 drawings and I start to edit them the tab order is from 15 to 14 to 13... but I edit starting with drawing 1 and then go to 2...
Hope that helps clear it up
Thanks
Edit..DWGMan did what I needed. Thank you.
I agree with Tiger, unless there is a specific reason for the drawings to be edited in order, why rearrange the tabs?? In any event, using Quick View, for some reason if you open up multiple drawings at once, AutoCAD mixes up the tabs... But if you open them up one at a time in the orde you want, the tabs will be however you want
