[error]Autodesk inventor 2008 professional Extrude
Hi i got a problem when i trie to extrude somthing in inventor the inventor just close and a pop up comes up and there say that i can report the error. anyone knows how to fix it??
Srry if wrong section
I take it this problem is with one model and not all the models you do? can you post the model sowe can have a look?
IS with anything i cant extrude anything if i try to make a square or cirle or anything it dont work :S
I have moved your thread to the Inventor-forums, hope you find some help here.
Does the problem persist after reboot?
Did it ever work correclty on this machine?
Did you already try a repair install?
2008 is an old release, it can be assumed it has been installed for a while. Over time computers pick up a lot of garbage - we reformat our computers at least yearly to clean the system.
i installed it for 3 days ago :o and i have tried to repair :( dont work
I could be wrong, but a fresh install of an old release might not have all the updated service packs and whatnot... possibly investigate update info??
What is the operating system?
Other system specs?
Windows 7 64bit
8gb ram
maxcube 800w
intel i7 2,67ghz Nivdia Geforce gt 220
500gb hdd
21,5 hd flat screen
2008 is not certified for a 64-bit OS
Did you turn off UAC before install?
