Hi all,
I have been playing around with an autolisp function that will automatically fillet a polyline. At the moment the following will allow you to draw and fillet a polyline with a 300mm radius on the Flex-CR layer.
I would like the ability to copy the way the fillet command works, getting the current radius, allowing a different radius to be entered (if Ent is pressed, use current value) then store that value for next time but for the life of me cant work out how to get, use and re-store the current fillet radius.
(defun c:FlexLine ( / *error* LastEntity OldLayer pt ent )
 (defun *error* ( msg )
   (and OldLayer (setvar "CLAYER" OldLayer))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq LastEntity (entlast) OldLayer (getvar "CLAYER"))
 (or (tblsearch "LAYER" "FLEX-CR")
     (command "_.-layer" "_M" "FLEX-CR" ""))
 (if
   (and (setq pt (getpoint "\nSpecify start point: "))
       (setvar "CLAYER" "FLEX-CR")
       (command "_.pline" pt "_W" 0.0 0.0)
       (while (= 1 (logand 1 (getvar 'CMDACTIVE)))
         (command pause))
       (not (equal LastEntity (setq ent (entlast))))
     (setvar "FILLETRAD" 300)
     (command "_.fillet" "_P" ent)
Any help greatly appreciated.
Hi
Maybe as a starting point
     (if
(setq input
       (getdist
	 (strcat
	   "\nSpecify fillet radius <"
	   (rtos (getvar 'filletrad)) ">:")
(setvar 'filletrad input)
There are probably a few other ways you could also achieve this as well
Thanks for the feed back. Will have a play at the weekend. As a side note, Jammie, how would you combine this code into the other lisp code I posted?
Cheers,
Dave
Have had some success.
Code:
(defun c:FlexLine (/ *error* LastEntity OldLayer pt eLast ent)
   (princ))
 (or (tblsearch "LAYER" "flex-cr")
     (command "_.-layer" "_M" "flex-cr" ""))
 (setvar 'filletrad
         (cond ((getdist (strcat "\nSpecify fillet radius <" (rtos (getvar 'filletrad)) ">: ")))
               ((getvar 'filletrad))
 (if (setq pt (getpoint "\nSpecify start point: "))
;      (setq eLast (entlast))
     (setvar "CLAYER" "flex-cr")
     (command "_.pline" "_non" pt)
     (while (= 1 (logand (getvar 'cmdactive) 1))
       (princ "\nSpecify next point: ")
       (command PAUSE)
     (or (equal eLast (setq ent (entlast)))
works a treat.
Thanks to all.
Your could add it pre the polyline command
   (princ))
 (if
(setq input
       (getdist
	 (strcat
 (if
         (command pause))
or post
   (princ))
 (if
         (command pause))
     (if
(setq input
       (getdist
	 (strcat
Although your new code seems to work well. Glad you got it sorted
Regards
Jammie
Thanks for the help and feedback.
Dave
