As a way to standardise our cad files I need a way to change the text layer based on its height. any help appreciated.
You can use QSELECT to select all text-objects with a specific height, then you can manually change the layer.
That is the way I have been doing it previously but I wanted to know if there was a way to do this in a LISP routine so I simply type the command and it fixes it all?
Do you want help with writing a lisp routine, or were you hoping someone would provide it for you?
Step through a selection set of text and use 'cond' to match text height with predefined criteria and place on appropriate layer.
I have moved your thread to the Lisp forum, hope you find what you seek here.
This will you get to started,
just change on desired layer names
(defun C:CHLT(/ *error* elist en exist ss)
 ;;error trapping function
   (defun *error* (msg)
   (cond ((or (not msg)
       (member msg '("console break" "Function cancelled" "quit / exit abort"))
  ((princ (strcat "\nError: " msg)))
     (command "._layerp")
     (command "._undo" "_end")
     (command)
;;local defun
 (defun _get_layer_name (height)
   (cond ((zerop height) nil)
  ((equal 1.0 height) "Layer1")
  ((equal 1.5 height) "Layer2")
  ((equal 2.0 height) "Layer3")
  ((equal 2.5 height) "Layer4")
  ;;etc...
  );<--change  on appropriate layers here
(prompt "\n  >>  Select text objects to apply the layers by text height  >>")
(if (setq ss (ssget ":L" (list (cons 0 "TEXT"))))
   (command "._undo" "_begin")
   (command "._layer" "_on" "*" "")
   (while
     (setq en (ssname ss 0))
     (setq elist (entget en))
     (if (setq exist  (_get_layer_name (cdr (assoc 40 elist))))
       (setq elist (subst (cons 8 exist)(assoc 8 elist) elist))
       (entmod elist)
(entupd en)
     (ssdel en ss))
   (*error* nil)
~'J'~
Or maybe for a total global change:
 [b][color=BLACK]([/color][/b]setq th '[b][color=FUCHSIA]([/color][/b][b][color=NAVY]([/color][/b]1.0 . [color=#2f4f4f]"LAYER1"[/color][b][color=NAVY])[/color][/b]
            [b][color=NAVY]([/color][/b]2.0 . [color=#2f4f4f]"LAYER2"[/color][b][color=NAVY])[/color][/b]
            [b][color=NAVY]([/color][/b]3.0 . [color=#2f4f4f]"LAYER3"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
 [b][color=BLACK]([/color][/b]foreach g th
    [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"*TEXT"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 40 [b][color=RED]([/color][/b]car g[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]progn
          [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] [b][color=RED]([/color][/b]cdr g[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
              [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color] [color=#2f4f4f]"_N"[/color] [b][color=BLUE]([/color][/b]cdr g[b][color=BLUE])[/color][/b] [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
          [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.CHPROP"[/color] ss [color=#2f4f4f]""[/color] [color=#2f4f4f]"_LA"[/color] [b][color=GREEN]([/color][/b]cdr g[b][color=GREEN])[/color][/b] [color=#2f4f4f]""[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
