ordengate Posted September 30, 2010 Posted September 30, 2010 I'm trying to take a block that has an attribute and 'tag' it with an mtext text field to be used with the eattext command. I cannot for the life of me figure out how to do this. Can anyone give me some pointers? It gets old when you have 100 blocks and have to manually insert a text field next to it. Quote
BIGAL Posted October 1, 2010 Posted October 1, 2010 Theres no problem to pull an attribute value out of a block and then write it as mtext, search here for a recent problem "getting 4th attribute" Lee mac and AlanJT have some extensive block routines posted here and I have posted an example soloution getting attributes using VBA multi times. Sounds like you didn't do a search first. Quote
alanjt Posted October 1, 2010 Posted October 1, 2010 Sounds like you didn't do a search first.Sadly, few ever do. Quote
fixo Posted October 1, 2010 Posted October 1, 2010 I'm trying to take a block that has an attribute and 'tag' it with an mtext text field to be used with the eattext command. I cannot for the life of me figure out how to do this. Can anyone give me some pointers? It gets old when you have 100 blocks and have to manually insert a text field next to it. Welcome on board! Try this quick example (vl-load-com) (defun C:MField(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (setq tag (getstring "\nEnter tag <MODIF_A> : "));<--change on appropriate tag here (if (eq (chr 0) tag) (setq tag "MODIF_A"));<--change on appropriate tag here (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location >> ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<[url="file://acobjprop/"]\\AcObjProp[/url] Object(%<[url="file://_objid/"]\\_ObjId[/url] " (itoa id) ">%).TextString [url="file://f/"]\\f[/url] \"%tc4\">%"));<--\"%tc4\" is title case, you can remove it ) ) ) ) (princ) ) ~'J'~ Quote
ordengate Posted October 1, 2010 Author Posted October 1, 2010 That will definitely get me started. Thank you so much. Is there a guide for VLA programming in LISP I can read to try and reproduce this on other things? Also, sorry I didn't do a search. Generally I use google to search multiple sites and after checking 10 pages trying to figure this out, I gave up and posted on here. Quote
ordengate Posted October 1, 2010 Author Posted October 1, 2010 One other question: How do I set the justification? I found this snippet on another thread, but I can't seem to work it in (vlax-put mtxtobj 'AttachmentPoint acAttachmentPointMiddleCenter) Ultimately I'd like one command for each of the nine justifications. Otherwise the version I've reworked from your code works wonderfully. Quote
fixo Posted October 1, 2010 Posted October 1, 2010 (edited) That will definitely get me started. Thank you so much. Is there a guide for VLA programming in LISP I can read to try and reproduce this on other things? Also, sorry I didn't do a search. Generally I use google to search multiple sites and after checking 10 pages trying to figure this out, I gave up and posted on here. This is my favourite web site http://www.afralisp.net/visual-lisp/ the best one, IMHO You can also download VisulLisp Developer Bible.pdf from there http://sites.google.com/site/visuallispbible/downloads ~'J'~ Edited October 1, 2010 by fixo Quote
fixo Posted October 1, 2010 Posted October 1, 2010 One other question: How do I set the justification? I found this snippet on another thread, but I can't seem to work it in (vlax-put mtxtobj 'AttachmentPoint acAttachmentPointMiddleCenter) Ultimately I'd like one command for each of the nine justifications. Otherwise the version I've reworked from your code works wonderfully. After you've changed the Attachment point property of mtext object, you need to put insertion point back: (setq inspt (vla-get-insertionpoint mtxtobj)) (vla-put-attachmentpoint mtxtobj acAttachmentPointMiddleCenter) (vla-put-insertionpoint mtxtobj inspt) ~'J'~ Quote
ordengate Posted October 1, 2010 Author Posted October 1, 2010 After you've changed the Attachment point property of mtext object, youneed to put insertion point back: (setq inspt (vla-get-insertionpoint mtxtobj)) (vla-put-attachmentpoint mtxtobj acAttachmentPointMiddleCenter) (vla-put-insertionpoint mtxtobj inspt) ~'J'~ I've tried adding that bit to the code you gave me previously, but it's still putting the justification point at the top left. I'm eventually going to want to offset the text as well. My original code to do that was as follows: (DEFUN MTTL () (SETVAR "CMDECHO" 0) (SETQ SCALE (/ 1 (GETVAR "CANNOSCALEVALUE"))) (SETQ MTPOINT (GETPOINT "\NENTER JUSTIFICATION POINT: ")) (SETQ MTHEIGHT (* SCALE 0.078125)) (SETQ MTX (+ (CAR MTPOINT) (* SCALE 0.03125))) (SETQ MTY (- (CADR MTPOINT) (* SCALE 0.0390625))) (COMMAND "MTEXT" (LIST MTX MTY) "J" "TL" "H" MTHEIGHT "R" "0" "W" "0" V:TEXT "") (SETVAR "CMDECHO" 1) ) Is this something I can do to the insertion point? Quote
fixo Posted October 1, 2010 Posted October 1, 2010 (edited) I've tried adding that bit to the code you gave me previously, but it's still putting the justification point at the top left. I'm eventually going to want to offset the text as well. My original code to do that was as follows: (DEFUN MTTL () (SETVAR "CMDECHO" 0) (SETQ SCALE (/ 1 (GETVAR "CANNOSCALEVALUE"))) (SETQ MTPOINT (GETPOINT "\NENTER JUSTIFICATION POINT: ")) (SETQ MTHEIGHT (* SCALE 0.078125)) (SETQ MTX (+ (CAR MTPOINT) (* SCALE 0.03125))) (SETQ MTY (- (CADR MTPOINT) (* SCALE 0.0390625))) (COMMAND "MTEXT" (LIST MTX MTY) "J" "TL" "H" MTHEIGHT "R" "0" "W" "0" V:TEXT "") (SETVAR "CMDECHO" 1) ) Is this something I can do to the insertion point? Sorry, I was a bit busy with my own This code is working good on my machine (I used A2009) Try again (vl-load-com) (defun C:MField(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (setq tag (getstring "\nEnter tag <MODIF_A> : "));<--change on appropriate tag here (if (eq (chr 0) tag) (setq tag "MODIF_A"));<--change on appropriate tag here (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nSpecify a field location >> ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<[url="file://acobjprop/"]\\AcObjProp[/url] Object(%<[url="file://_objid/"]\\_ObjId[/url] " (itoa id) ">%).TextString [url="file://f/"]\\f[/url] \"%tc4\">%"))) (vla-put-attachmentpoint mtxtobj acAttachmentPointMiddleCenter) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) ~'J'~ Edited October 1, 2010 by fixo spell check Quote
ordengate Posted October 1, 2010 Author Posted October 1, 2010 Finished product for anyone interested. Thanks again for the help. (vl-load-com) (DEFUN C:TID () (SETQ V:JUST "TL") (SETQ V:JUST (GETSTRING "Justification: (TL,TC,TR,ML,MC,MR,BL,BC,BR) <TL>: ")) (IF (OR (= "TL" V:JUST) (= "tl" V:JUST) (= "" V:JUST)) (INSIDTL) (PRINC)) (IF (OR (= "TC" V:JUST) (= "tc" V:JUST)) (INSIDTC) (PRINC)) (IF (OR (= "TR" V:JUST) (= "tr" V:JUST)) (INSIDTR) (PRINC)) (IF (OR (= "ML" V:JUST) (= "ml" V:JUST)) (INSIDML) (PRINC)) (IF (OR (= "MC" V:JUST) (= "mc" V:JUST)) (INSIDMC) (PRINC)) (IF (OR (= "MR" V:JUST) (= "mr" V:JUST)) (INSIDMR) (PRINC)) (IF (OR (= "BL" V:JUST) (= "bl" V:JUST)) (INSIDBL) (PRINC)) (IF (OR (= "BC" V:JUST) (= "bc" V:JUST)) (INSIDBC) (PRINC)) (IF (OR (= "BR" V:JUST) (= "br" V:JUST)) (INSIDBR) (PRINC)) ) (DEFUN C:TCIRC () (SETQ V:JUST "TL") (SETQ V:JUST (GETSTRING "Justification: (TL,TC,TR,ML,MC,MR,BL,BC,BR) <TL>: ")) (IF (OR (= "TL" V:JUST) (= "tl" V:JUST) (= "" V:JUST)) (INSCIRCTL) (PRINC)) (IF (OR (= "TC" V:JUST) (= "tc" V:JUST)) (INSCIRCTC) (PRINC)) (IF (OR (= "TR" V:JUST) (= "tr" V:JUST)) (INSCIRCTR) (PRINC)) (IF (OR (= "ML" V:JUST) (= "ml" V:JUST)) (INSCIRCML) (PRINC)) (IF (OR (= "MC" V:JUST) (= "mc" V:JUST)) (INSCIRCMC) (PRINC)) (IF (OR (= "MR" V:JUST) (= "mr" V:JUST)) (INSCIRCMR) (PRINC)) (IF (OR (= "BL" V:JUST) (= "bl" V:JUST)) (INSCIRCBL) (PRINC)) (IF (OR (= "BC" V:JUST) (= "bc" V:JUST)) (INSCIRCBC) (PRINC)) (IF (OR (= "BR" V:JUST) (= "br" V:JUST)) (INSCIRCBR) (PRINC)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun INSIDTL(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointTopLeft) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDTC(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointTopCenter) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDTR(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointTopRight) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDML(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointMiddleLeft) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDMC(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointMiddleCenter) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDMR(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointMiddleRight) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDBL(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointBottomLeft) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDBC(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointBottomCenter) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) (defun INSIDBR(/ acsp atts blk_obj ent found id pt tag) (while (setq ent (entsel "\nSelect block instance (or press Enter to Exit): ")) (setq blk_obj (vlax-ename->vla-object (car ent))) (Setq tag "ID") (if (eq (chr 0) tag) (setq tag "ID")) (setq atts (vlax-invoke blk_obj 'getattributes)) (foreach att atts (if (eq (vla-get-tagstring att) tag) (progn (setq found (vla-get-textstring att)) (setq id (vla-get-objectid att)) (setq pt (getpoint "\nPick a field location: ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq mtxtobj (vlax-invoke-method acsp 'addmtext (vlax-3d-point pt) 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa id) ">%).TextString \\f \"%tc4\">%")) ) (vla-put-attachmentpoint mtxtobj acAttachmentPointBottomRight) (vla-put-insertionpoint mtxtobj (vlax-3d-point pt)) ) ) ) ) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Quote
