Is there a feature in inventor to do a boundary blend like pro e where 2 sketches can be selected and it will blend the two shapes with a solid and the the running profiles can be edited after? Or is there only the lofting command?
Thanks
Right scrap that i figured my sketch was open, next question how can you check that your sketch is a closed loop? Pro e had a function where it pin pointed where the sketch is not connected. How do i do that on inventor? Thankkss
right click when in sketch mode, select sketch doctor. This will tell you any problems that need to be resolved with the current sketch
