ordengate Posted October 5, 2010 Posted October 5, 2010 I usually keep the properties palette always open to fill out blocks with attributes. Instead of going to the next attribute now though when I hit enter, it's jumping back to the command line. Any way to stop this? Quote
BlackBox Posted October 5, 2010 Posted October 5, 2010 Perhaps, using the Tab key will work for you...? Quote
ordengate Posted October 6, 2010 Author Posted October 6, 2010 Perhaps, using the Tab key will work for you...? Same thing. For some reason as soon as it changes anything on the properties palette, it jumps back to the command line. Quote
BlackBox Posted October 6, 2010 Posted October 6, 2010 Same thing. For some reason as soon as it changes anything on the properties palette, it jumps back to the command line. Where is your mouse pointer when you make changes in the properties panel? I *believe* if your mouse (crosshairs) are hovering over the properties panel (not in modelspace), then the panel remains active. Also, I leave mine 'docked' and do not experience this problem. Edit: Then again, it could just be a quirky behavior of MEP, for all I know? lol Quote
ordengate Posted October 6, 2010 Author Posted October 6, 2010 Where is your mouse pointer when you make changes in the properties panel? I *believe* if your mouse (crosshairs) are hovering over the properties panel (not in modelspace), then the panel remains active. Also, I leave mine 'docked' and do not experience this problem. Edit: Then again, it could just be a quirky behavior of MEP, for all I know? lol My mouse is usually over the properties palette. My palette is also docked with auto-hide turned off. I've just started noticing this with MEP 2011. Never had this issue with BS 2007.1 Quote
