amhere Posted July 22, 2025 Posted July 22, 2025 On 10/7/2010 at 1:10 PM, irneb said: Well, a "quick-fix" solution would be to use the ObjectScale command's command-line arguments. (defun c:ObjectScaleCurOnly (/ ss n scLst OSC:GetScales) (print "Select the objects you wish to modify: ") (if (or (setq ss (ssget "I")) (setq ss (ssget))) (progn ;; Define helper function to get scales attached to an entity (defun OSC:GetScales (en / ed xn xd cdn cdd asn asd cn cd sn sd cannoscale) (setq ed (entget en)) (if (and ;; Get the XDictionary attached to the object (setq xn (vl-position '(102 . "{ACAD_XDICTIONARY") ed)) (setq xn (cdr (nth (1+ xn) ed))) (setq xd (entget xn)) ;; Get the Context Data Management dictionary attached to the XDictionary (setq cdn (vl-position '(3 . "AcDbContextDataManager") xd)) (setq cdn (cdr (nth (1+ cdn) xd))) (setq cdd (entget cdn)) ;; Get the Annotation Scales dictionary attached to the CD (setq asn (vl-position '(3 . "ACDB_ANNOTATIONSCALES") cdd)) (setq asn (cdr (nth (1+ asn) cdd))) (setq asd (entget asn)) ;; Get the 1st scale attached (setq cn (assoc 3 asd)) (setq cn (member cn asd)) ) ;; Step through all scales attached (while cn (if (and (= (caar cn) 350) ;It it's pointing to a scale record ;; Get the record's data (setq cd (entget (cdar cn))) ;; Get the Context data class (setq sn (assoc 340 cd)) (setq sd (entget (cdr sn))) (setq sn (assoc 300 sd)) ;; Check if the scale is already in the list (not (vl-position (cdr sn) scLst)) ) ;; Add it to the list (setq scLst (cons (cdr sn) scLst)) ) (setq cn (cdr cn)) ) ) ) ;; Find a list of scales used in selection (setq n (sslength ss)) (while (>= (setq n (1- n)) 0) (OSC:GetScales (ssname ss n)) ) ;; Add the current scale to the selection (setq cannoscale (getvar "CANNOSCALE")) (command "._ObjectScale" ss "" "_Add" cannoscale "") ;; Remove all other scales attached (command "._ObjectScale" ss "" "_Delete") (foreach n scLst (if (wcmatch (strcase n) (strcat "~" (strcase cannoscale))) (command n) ) ) (command "") ) ) (princ) ) The problem with anno scales are that they are nested 5 levels deep into the dictionaries attached to the entity. Dear irneb, pBe, Your code is excellent, but I have an issue that I need help with. The code works fine when selecting only annotative objects. However, when selecting multiple objects for the code to automatically detect and process, it doesn’t completely remove all the excess annotation scales. Could you please help me revise the code to fix this? Quote
