I cant seem to get AutoCAD 2011 up and running. iv downloaded from Autodesk but when i run the program it says 'not reconised' . Is there anyone facing the same problem? or can someone help me?:)
get a dealer to send you out a DVD
What do you mean by, "when I run the program..."?
Did you get it installed?
If running Vista or Windows 7 did you turn off UAC before install?
during install it comes up with that message........ 'not reconised'
how do i switch off UAC ???
Did you download the correct version? There is a 32-bit and 64-bit version. What version of windows are you running and is it 32-bit or 64-bit?
yes i have downloaded the right version but it doesnt seem to work. i downloaded it from the Autodesk website (the student version)
Are you running Windows XP, Vista or 7?
Home Premium, Professional or Ultimate?
Are you sure you downloaded the 64-bit version? How fast is your connection speed? In my experience if it takes more than 3-4 hours the download is corrupt. Is it just 1 exe download or is there also an rar download? If there is an rar - do not try to unzip it. The exe is self-extracting and will extract the rar. Post a screen shot of the exact error message.
i will try to post a screen shot but im not to familiar with computers yet:)
it took over 3-4 hours to download i saved it, then a install message came up so i pressd ok, then afta the install it comes up with the error message then it slows my computer down real slow:(
anyways you guys just post me your suggestions i'll try n have a look tomorrow. im done for today. thanks:thumbsup:
My comp specs:
Product NumberWQ275EAMicroprocessor2.3 GHz AMD Turion II Dual-Core Processor P520Microprocessor CacheLevel 2 cache 2 MBMemory4 GB DDR3 (2 x 2048 MB)Memory MaxSupports up to 4 GB DDR3 memoryVideo GraphicsATI Mobility Radeon HD 4250 GraphicsVideo Memoryup to 2046 MB total available graphics memoryDisplay39.6 cm (15.6") diagonal High-Definition LED HP BrightView Display (1366 x 768)Hard Drive320 GB SATA Hard Disk Drive 7200 rpmMultimedia DriveSATA optical drive: LightScribe SuperMulti DVD±R/RW with Double Layer SupportNetwork CardIntegrated 10/100BASE-T Ethernet LANWireless ConnectivityBluetooth wireless networking
802.11 b/g/nSoundAltec Lansing speakersKeyboardFull size keyboard with One touch launch keys and Action keysPointing DeviceTouch Pad with On/Off button and 2-way Scroll pad supportPC Card Slots5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro or xD Picture cardsExternal Ports
  • 1 VGA port
  • 1 HDMI port
  • 1 stereo headphone-out
  • 1 microphone-in
  • 3 USB 2.0 ports
  • 1 RJ45 ethernet port
Dimensions24.6 cm (L) x 37.4 cm (W) x 3.18 cm (min H) / 3.68 cm (max H)Weight2.2 kgPower65 W AC Power Adapter
6-cell Lithium-Ion (Li-Ion) battery
