Hey guys, I am currently using autocad 2008, I've created a shape and meshed a surface using rulesurf. I was just wondering if it can be converted into a solid object.
The File is attached
aero.dwg
I don't believe your object can be converted to a solid in AutoCAD.
  • 5 years later...
Extrude the larger of the plan view polylines then trim with the slice command to create your solid.
