I have 200 drgs with the drawing numbers justified incorrectly what sort of lisp routine could i target them with, all the first 8 digits of the drg numbers are the same on each one so a wild card targeting should work.
Its single line text not even mtext, not attributes Im affraid
refer to this thread for text justification (soulution by Lee Mac)
http://www.cadtutor.net/forum/showthread.php?29254-Text-Justification-Routine-Help&highlight=text+justification
The routine is easy.. the real problem is running in through 200 drawings,
just remember to change the DXF 72 code to suite your needs.
heres a guide:
;DXF 72
; Horizontal text justification type (optional, default = 0) integer codes (not bit-coded)
;0 = Left; 1= Center; 2 = Right
;3 = Aligned (if vertical alignment = 0);
;4 = Middle (if vertical alignment = 0);
;5 = Fit (if vertical alignment = 0);
;See the Group 72 and 73 integer codes table for clarification
Now you can either use a script or used ObjectDBX (which i'm still trying to learn :))
still you need a routine for string matching...
(wcmatch "your string" "pattern*")
chagne the line 11 to something like this..
(IF  (AND (= enttyp "TEXT")
       (wcmatch (cdr (assoc 1 ent1)) "YOUR 8 DIGIT*")
(progn .....
and oh.. dont forget to change dxf 72 to suit you neeeds
Wow - that is old code, I'm embarassed to see that dragged up again lol :oops:
Here is a quick code, slapped together:
(defun c:tJust ( / 72code 73code ss )
 ;; © Lee Mac 2010
 (setq 72code 1 73code 2)
 (if (setq ss (ssget "_X" '((0 . "TEXT") (1 . "12345678*"))))
     (lambda ( i / x l )
       (while (setq x (ssname ss (setq i (1+ i)))) (setq l (entget x))
         (entupd
           (cdr
             (assoc -1
               (entmod
                 (subst (cons 72 72code) (assoc 72 l)
                   (subst (cons 73 73code) (assoc 73 l)
                     (subst
                       (cons 11 (cdr (assoc 10 l))) (assoc 11 l) l
     -1
Change the 72/73 code and filter as necessary.
Man!!! 2008!!
:oops: Now I’m embarrassed.. apologies Lee Mac
You’ve come a long way since then..
Think of it this way, you wouldn’t have gotten as good as you are if you hadn’t gone through all that
No worries mate, I was just joking with you :P
But yeah, we all have to start somewhere :)
