Hey, is there anyway to store a variable in autocad. So that the next time autocad is opened, the lisp program is loaded and it can call a variable from the previous time it was ran?
Is there anyway to have cad pre-load your lisp program when autocad is opened. Just to save the step of loading applications.
Also, is there a lisp command to output the date and time?
Thanks for you help!
Look in the help file for system variables: USERR1, USERR2 etc
You can add a macro to your custom CUI so that it loads automatically whether using a pulldown or toolbar etc. You can also use the Acaddoc.lsp file (which you will need to create)and the Startup Suite in the appload dialog box.
Try this...
;Get time and date
;Get Date
(defun c:GetDateTime ( / )
(setq d (rtos (getvar "CDATE") 2 6)
     yr (substr d 3 2);extract the year
     mo (substr d 5 2);extract the month
     day (substr d 7 2);extract the day
);setq
;Get Time
(setq d (rtos (getvar "CDATE") 2 6);extract the hour
     hr (substr d 10 2)
     m (substr d 12 2);extract the minute
);setq
(alert
(strcat
 "Date: "(strcat day "/" mo "/" yr)
 "\nTime: "(strcat hr ":" m )
);strcat
);alert
);defun
Edited by Small Fish
With your second point:
In a predefind autocad directory or make one yourself in 'options - Files - Support file search path'
Start a notepad file with the name 'acaddoc.lsp'
Put:
(defun s:: startup ()
(command "ucs" "world")
(defun c:mco () (load "mymacro"))
This will make sure everytime you open Autocad the drawings UCS will be 'world' and if you type 'mco' in the command line mymacro will run
You could also make this file 'acad.lsp' and in 'options - system' there is a 'load acad.lsp with every drawing' - check this and the same thing will happen.
With your third point:
try typing 'setvar' 'enter' '?' 'enter' 'enter' and most of the variables for autocad come up and you will be able to call these (and change some if needed) for the date and time. Another one I use is:
(setq daytext (menucmd "m=$(edtime,$(getvar, date),dddd)"))
(setq monthtext (menucmd "m=$(edtime,$(getvar, date),month)"))
(setq yeartext (menucmd "m=$(edtime,$(getvar, date),yyyy)"))
For your first point: Can't think of a good way of doing that one except writing a script file within your lisp routine to store that variable and look for that script file when the lisp routine is re-run
Hope this helps
For the date:
(defun LM:FormatDate ( format )
 (menucmd (strcat "m=$(edtime,$(getvar,DATE)," format ")"))
Where format is of the form:
D:       day                             4
DD:      day with leading zero          04
DDD:     day of week short             Mon
DDDD:    day of week long              Monday
M:       month                           6
MO:      month with leading zero        06
MON:     month name short              Jun
MONTH:   month name long               June
YY:      year two places                 89
YYYY:    year four places              1989
H:       hour                             7
HH:      hour with leading zero          07
MM:      minutes                         30
SS:      seconds                         30
MSEC:    milliseconds                   300
AM/PM:   upper case AM or PM             AM
am/pm:   lower case am or pm             am
A/P:     upper case  A or P               A
a/p:     lower case  a or p               a
Some Examples:
(LM:FormatDate "DD.MO.YYYY HH:MM:SS")
(LM:FormatDate "DDDD DD MONTH YYYY")
(LM:FormatDate "H:MM AM/PM")
(LM:FormatDate "DDDD DD/MO/YYYY HH:MM:SS:MSEC")
