What is, and how do I change the SDI mode in Land Desktop 2004 ?
Type SDI on command line...(I got plain Autocad)
SDI stands for Single Document Interface. When it's set to 1 you open 1 drawing at a time. When it is set to 0, you can open multiple drawings within one session of Autocad.
I could be wrong, but im not sure LDD supports SDI... the test would be as mdbdesign suggested...
In Land Desktop 2004, SDI should be set to 3 (single document open at a time) and read-only (see this post for more info on SDI settings)
Starting with LDT 2007, SDI is set to 0, allowing multiple documents to be open but there are some things to consider. See: http://support.autodesk.com/getDoc.asp?id=TS1057006
Edited by rkmcswain
fix url
