Temporarily Disable Perspective View
Because certain commands are not available in a prespective view, I'm trying to figure how to temporarily set VIEWMODE to 0 ( turn prespective off )
It is turned on by changing the distance parameter in the DVIEW command. I haven't figured out how to calulate the distance required to reset the variable to 0. I want to keep the same basic viewctr, viewdir and zoom etc. Just be able to pick say a base point to pan or move.
I would simply use (command "_.ZOOM" "_Prev") to restore the perspective.
Any ideas? TIA -David
