muck Posted October 13, 2010 Posted October 13, 2010 Is there a way to make AutoCAD's open default directory be the directory of the last opened file directory no matter if it open by AutoCAD open or MS explorer? If you go into MS explorer and open an AutoCAD file, AutoCAD opens it and uses it but when I use the AutoCAD open command in the next scission it defaults to a different directory. Is there a way to make the two default directories match? Thank you. Quote
CyberAngel Posted October 13, 2010 Posted October 13, 2010 I was always told to open drawings through AutoCAD, not through Explorer. That would solve your problem, even though that's not the question you asked. To answer the question you did ask, I don't know. I would guess that it is not possible. Quote
JPlanera Posted October 13, 2010 Posted October 13, 2010 I was always told to open drawings through AutoCAD, not through Explorer. That would solve your problem, even though that's not the question you asked. To answer the question you did ask, I don't know. I would guess that it is not possible. Agreed, I see no need to open drawings through explorer. In case OP did not know, you can define the default "Start in" directory by opening the properties of the desktop icon for acad... Quote
ReMark Posted October 13, 2010 Posted October 13, 2010 Look at this from AutoDesk: "For the Start In folder to be recognized as the default location when working with files, set the REMEMBERFOLDERS system variable to 0 (off). The REMEMBERFOLDERS system variable controls the default path for the Look In or Save In option in standard file selection dialog boxes. A setting of 0 restores legacy behavior, using the Start In path. With a setting of 1, the last used path in each file selection dialog box is remembered across all drawing sessions." Quote
rkent Posted October 13, 2010 Posted October 13, 2010 Create a command in CUI with this macro, then drag that up to any toolpalette. ^C^C^P(startapp "explorer" (getvar "dwgprefix")) I learned this on one of the forums, not my solution. Quote
muck Posted October 14, 2010 Author Posted October 14, 2010 Reason I want to do this is because I work on a large server with a lot of folders. I save desktop shortcut icons to those folders that I work on. AutoCAD needs to remember what directory it is in when it saves a file that was opened by explorier. If there was a way for explorier to let AutoCAD know its opened folder then AutoCAD could be set its default folder. Maybe a Batch, Lisp or maybe VBA routine would work here? Thank you, Quote
nukecad Posted October 14, 2010 Posted October 14, 2010 AutoCAD needs to remember what directory it is in when it saves a file that was opened by explorer I also work on a large server with thousands of folders and sub-folders. Rather than using desktop shortcuts to folders, my solution is to save the 9 or 10 folders that I am working in at any time to the FAVOURITES list. Then in Autocad when opening a drawing I can just click on the favourites list to go to the folder and pick the drawing to open. OR in explorer I can click on the favourites list to go to the folder and double click the drawing to open. If you use QSAVE then the drawing is saved back wherever it came from. If you want to SAVEAS in the same folder then you can just pick it from the favourites list. Quote
Squirltech Posted October 14, 2010 Posted October 14, 2010 I was always told to open drawings through AutoCAD, not through Explorer. That would solve your problem, even though that's not the question you asked. Thank you for this. I am always telling people, where I work, this rule. I think it will become my signature on CADTutor. Quote
rkent Posted October 14, 2010 Posted October 14, 2010 Reason I want to do this is because I work on a large server with a lot of folders. I save desktop shortcut iconsto those folders that I work on. AutoCAD needs to remember what directory it is in when it saves a file that was opened by explorier. If there was a way for explorier to let AutoCAD know its opened folder then AutoCAD could be set its default folder. Maybe a Batch, Lisp or maybe VBA routine would work here? Thank you, As I posted earlier, this is a very simple solution. Create a command in CUI with this macro, then drag that up to any toolpalette. ^C^C^P(startapp "explorer" (getvar "dwgprefix")) I learned this on one of the forums, not my solution. Quote
