Arny Posted February 16, 2006 Posted February 16, 2006 Further to recent topics, I have discovered I can create a hatch from an image in Superhatch but although showing as seamless on screen, it is plotting with some of the joins between the 'tiles' or possibly the image frame showing as white. Does anyone know how to stop this? (I have the imageframe set to off.) Thanks Quote
f700es Posted February 16, 2006 Posted February 16, 2006 Further to recent topics, I have discovered I can create a hatch from an image in Superhatch but although showing as seamless on screen, it is plotting with some of the joins between the 'tiles' or possibly the image frame showing as white. Does anyone know how to stop this? (I have the imageframe set to off.) Thanks I have seen this too. Not sure on how to stop it though. Not sure but might be with the texture file that you are using. I have seen it and not seen it so I wonder if that can the issue. Quote
Arny Posted February 17, 2006 Author Posted February 17, 2006 I thought it might be the image but then I downloaded the example from the Cadtutor tutorial (which should have been fine as they suggested you use it to try it out) and it still gave me white lines - not on every edge either, and randomly too it seems.... Quote
JuanPaulo Posted April 8, 2009 Posted April 8, 2009 Anybody has a last word on this issue? I am having the same problem. I have tried everything and even though the the lines do not show on screen they always appear on the plots. Like Arny, I triple checked the image for "border" lines but did not find any. Help please!!! Quote
